0005456 | ParaView | (No Category) | public | 2007-08-07 15:47 | 2007-08-27 19:13 | ||||
Reporter | Amy Squillacote | ||||||||
Summary | 0005456: tiled display window size | ||||||||
Description | When I run ParaView in tiled display mode, the render windows on the tiled display do not take up the full screen. Instead, they show up as small windows in the corner of the screen. This is without the PV_ICET_WINDOW_BORDERS environment variable set. | ||||||||
(0008575) Utkarsh Ayachit (administrator) 2007-08-21 22:29 |
SetFullScreen needed to be called after the render window etc. had initialized. Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx <-- new revision: 1.3; previous revision: 1.2 Servers/ServerManager/Resources/rendering.xml <-- new revision: 1.232; previous revision: 1.231 |
2007-08-07 15:47 | Amy Squillacote | New Issue | |
2007-08-07 15:47 | Amy Squillacote | Status | backlog => tabled |
2007-08-07 15:47 | Amy Squillacote | Assigned To | => Utkarsh Ayachit |
2007-08-21 22:29 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-21 22:29 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-21 22:29 | Utkarsh Ayachit | Note Added: 0008575 | |
2007-08-27 19:13 | Ken Moreland | Status | @80@ => closed |
