0005458 | ParaView | (No Category) | public | 2007-08-08 13:55 | 2007-09-10 22:32 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005458: LOD stuck when moving color bar widget | ||||||||
Description | create a superquadric set LOD threshold to zero color by texture coords show the color bar widget grab the color bar widget and move it around when you let go, you don't get a still render, but instead the LOD render stays. | ||||||||
(0008834) Utkarsh Ayachit (administrator) 2007-09-05 08:56 |
Representations that need to EnableLOD on the prop now do so whenever the ViewInformation changes, rather than relying on Update() being called. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSurfaceRepresentationProxy.cxx,v <-- vtkSMSurfaceRepresentationProxy.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSurfaceRepresentationProxy.h,v <-- vtkSMSurfaceRepresentationProxy.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUnstructuredGridVolumeRepresentationProxy.h,v <-- vtkSMUnstructuredGridVolumeRepresentationProxy.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMUnstructuredGridVolumeRepresentationProxy.cxx,v <-- vtkSMUnstructuredGridVolumeRepresentationProxy.cxx new revision: 1.13; previous revision: 1.12 |
2007-08-08 13:55 | Clinton Stimpson | New Issue | |
2007-08-29 15:44 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 15:44 | Berk Geveci | Priority | normal => high |
2007-08-29 15:44 | Berk Geveci | Status | backlog => tabled |
2007-08-29 15:44 | Berk Geveci | Category | => 3.2 |
2007-09-05 08:56 | Utkarsh Ayachit | Note Added: 0008834 | |
2007-09-05 09:09 | Berk Geveci | Status | tabled => @80@ |
2007-09-05 09:09 | Berk Geveci | Resolution | open => fixed |
2007-09-10 22:32 | Alan Scott | Status | @80@ => closed |
