0005501 | ParaView | (No Category) | public | 2007-08-15 10:26 | 2011-09-01 13:31 | ||||
Reporter | Mike Jackson | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Platform | OS X 10.4.10 (intel) | OS | OS X 10.4.10 | OS Version | 10.4.10 | ||||
Target Version | Fixed in Version | 3.12 | |||||||
Summary | 0005501: Display Lists are not being properly generated and called during polygonal mesh rendering. | ||||||||
Description | Using ParaView 3 from CVS (and also the 3-1-0 branch) attempting to render polygonal meshes results is low framerates. This can be reproduced by creating a sphere source and setting the phi and theta resolutions to 1024. This will create a sphere with about 2 million triangles. Interacting with this sphere will produce framerates of about 1 frame per second. Using "OpenGL Profiler" on OS X seems to show that the display is being created but never called as evidenced by the number of calls to glFloat3fv and glNormal3fv while glCallList is never called even when immediate mode rendering is OFF. This same test under ParaView 2.6.1 produced framerates of 25 to 30 FPS. LODs thresholds were turned OFF on all machines and versions of the programs. | ||||||||
Steps To Reproduce | Create a sphere source and set the theta and phi resolutions to 1024. | ||||||||
Additional Information | System information - Mac OS X 10.4.9/10 on a Mac Book Pro (core duo), Mac Book Pro (core 2 duo) and a 8 core Mac Pro with nVidea Quadro FX video card. Each Machine had at least 2GB of ram (8 GB on the Mac Pro) I also built VTK 5.0.3 and created a simple program that displayed my data set and was able to produce a framerate that is indicative of the video hardware being used, ie, about 30 FPS on a Core Duo Mac Book Pro with ATI X1600 video hardware. | ||||||||
(0011295) Berk Geveci (administrator) 2008-04-14 17:03 |
Can you please check if this is still the case? |
(0011302) Mike Jackson (reporter) 2008-04-14 18:19 |
This seems to be fixed with a ParaView CVS from a few weeks ago. |
(0013296) Mike Jackson (reporter) 2008-09-04 09:41 |
This seems to be back as of CVS Sept 2, 2008 |
(0013746) Mike Jackson (reporter) 2008-10-07 09:30 |
Still the case as of latest ParaView CVS from today. Where can I hunt this down? |
(0016933) Utkarsh Ayachit (administrator) 2009-07-22 09:45 |
Just verified with CVS ParaView that display lists are indeed created and used (glCallList is called on each render and glNewList is called just twice (once for full-res and once for LOD when interacting). |
(0016946) Alan Scott (manager) 2009-07-22 17:25 |
Not tested. Trusting Utkarsh's comment below. |
2007-08-15 10:26 | Mike Jackson | New Issue | |
2007-08-29 15:53 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 15:53 | Berk Geveci | Status | backlog => tabled |
2007-08-29 15:53 | Berk Geveci | Category | => 3.2 |
2008-04-14 17:03 | Berk Geveci | Note Added: 0011295 | |
2008-04-14 17:03 | Berk Geveci | Status | tabled => @20@ |
2008-04-14 17:03 | Berk Geveci | Resolution | open => unable to reproduce |
2008-04-14 17:03 | Berk Geveci | Category | => 3.4 |
2008-04-14 17:03 | Berk Geveci | Category | 3.4 => Development |
2008-04-14 18:19 | Mike Jackson | Note Added: 0011302 | |
2008-09-04 09:41 | Mike Jackson | Note Added: 0013296 | |
2008-10-07 09:30 | Mike Jackson | Note Added: 0013746 | |
2009-07-22 09:45 | Utkarsh Ayachit | Note Added: 0016933 | |
2009-07-22 09:45 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-07-22 09:45 | Utkarsh Ayachit | Fixed in Version | => Development |
2009-07-22 17:25 | Alan Scott | Note Added: 0016946 | |
2009-07-22 17:25 | Alan Scott | Status | @80@ => closed |
2011-09-01 13:31 | Utkarsh Ayachit | Fixed in Version | Development => 3.12 |
