0005517 | ParaView | (No Category) | public | 2007-08-16 13:53 | 2007-08-27 18:44 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005517: Object inspector information panel is not updated | ||||||||
Description | To reproduce: * Create sphere * apply * Check number of cells in the information panel * Change resolution * apply * Check number of cells in the information panel The number of cells is the same. To force the information panel to update, you have to select another source first and select sphere again. | ||||||||
(0008657) Utkarsh Ayachit (administrator) 2007-08-24 13:38 |
The data information was obtained before the render happend, however pipeline won't be updated until render happens, hence the data information obtained was obsolete. /cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyTabWidget.cxx,v <-- pqProxyTabWidget.cxx new revision: 1.15; previous revision: 1.14 |
2007-08-16 13:53 | Berk Geveci | New Issue | |
2007-08-16 13:54 | Berk Geveci | Status | backlog => tabled |
2007-08-16 13:54 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-08-24 13:38 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-24 13:38 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-24 13:38 | Utkarsh Ayachit | Note Added: 0008657 | |
2007-08-27 18:44 | Ken Moreland | Status | @80@ => closed |
