0005542 | ParaView | (No Category) | public | 2007-08-20 15:24 | 2008-04-14 17:13 | ||||
Reporter | Thomas Geenen | ||||||||
Summary | 0005542: using timeseries stored in a vtk xml file | ||||||||
Description | I would like to be able to store multiple time steps in a single vtk_xml file (no problem) and process them with paraview. Storing multiple time steps is supported in the vtk xml format however when opening such a file paraview tells me that there is only a single timestep. googling for some usefull comments resulted in some unsettling info. It seems that this is indeed not supported in paraview and that i will have to use the paraview format. however however this file type is more or less a list of vtk xml files (if I understood correctly). Does that mean that if i want to use any vtk based storage method i will have to store each time step in a separate file? and does this also mean that i will have to store the mesh info for each time step? We work with a fixed mesh and i am looking at storing hundreds of timestep. | ||||||||
Additional Information | assign to Berk Geveci | ||||||||
Attached Files | ![]() ![]() | ||||||||
(0008832) Berk Geveci (administrator) 2007-09-04 16:57 |
This is easy to enable but I need an example file to test. Please attach a small example. |
(0008854) Thomas Geenen (reporter) 2007-09-06 04:09 |
i attached the testroutine from VTK/IO/Testing/Cxx and the resulting vtu file with timesteps cheers Thomas |
(0008877) Thomas Geenen (reporter) 2007-09-07 04:51 |
will the solution you work on also work for pvtu files etc? |
(0008919) Berk Geveci (administrator) 2007-09-11 12:48 |
This now works with serial xml files (except composite data readers). I didn't enable it for distributed files because I am not sure how well it works and I don't have time to test it before 3.2 so I am reducing the priority. |
(0008938) Thomas Geenen (reporter) 2007-09-12 03:06 |
thanks i think this is a feature that many people will use! |
(0011297) Berk Geveci (administrator) 2008-04-14 17:13 |
I am closing this unless you have an pvtu example I can experiment with. |
2007-08-20 15:24 | Thomas Geenen | New Issue | |
2007-08-29 16:03 | Berk Geveci | Assigned To | => Berk Geveci |
2007-08-29 16:03 | Berk Geveci | Status | backlog => tabled |
2007-08-29 16:04 | Berk Geveci | Priority | normal => high |
2007-08-29 16:04 | Berk Geveci | Category | => 3.2 |
2007-09-04 16:57 | Berk Geveci | Note Added: 0008832 | |
2007-09-06 04:07 | Thomas Geenen | File Added: cube.vtu | |
2007-09-06 04:09 | Thomas Geenen | File Added: TestXMLCInterface.c | |
2007-09-06 04:09 | Thomas Geenen | Note Added: 0008854 | |
2007-09-07 04:51 | Thomas Geenen | Note Added: 0008877 | |
2007-09-11 12:48 | Berk Geveci | Note Added: 0008919 | |
2007-09-11 12:48 | Berk Geveci | Priority | high => normal |
2007-09-12 03:06 | Thomas Geenen | Note Added: 0008938 | |
2008-04-14 17:13 | Berk Geveci | Status | tabled => closed |
2008-04-14 17:13 | Berk Geveci | Note Added: 0011297 | |
2008-04-14 17:13 | Berk Geveci | Resolution | open => fixed |
