0005555 | ParaView | (No Category) | public | 2007-08-21 16:09 | 2007-09-10 22:22 | ||||
Summary | 0005555: Save Animation, Default No frames/timestep | ||||||||
Description | Load in can.ex2 and then select File->Save Animation. In the first dialog box, the default value for No. of Frames/timestep is 10. That does not make any sense. It seems to me that you would always (or at least almost always) want to save 1 frame per timestep. Otherwise you are just replicating the image a bunch of times each timestep. | ||||||||
(0008822) Utkarsh Ayachit (administrator) 2007-09-04 14:43 |
The FramesPerTimestep spin box was initialized with wrong variable. Fixed that. /cvsroot/ParaView3/ParaView3/Qt/Components/pqAnimationManager.cxx,v <-- pqAnimationManager.cxx new revision: 1.25; previous revision: 1.24 |
2007-08-21 16:09 | Ken Moreland | New Issue | |
2007-09-04 14:03 | Berk Geveci | Status | backlog => tabled |
2007-09-04 14:03 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-04 14:43 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-04 14:43 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-04 14:43 | Utkarsh Ayachit | Note Added: 0008822 | |
2007-09-10 22:22 | Alan Scott | Status | @80@ => closed |
