0005584 | ParaView | (No Category) | public | 2007-08-27 18:33 | 2007-08-29 12:18 | ||||
Summary | 0005584: Clamp animation values outside of keyframe range | ||||||||
Description | When an animation time is set outside of the range of keyframes for a particular property, it should clamp the value of that property to the closest keyframe. Otherwise, the animation gets messed up when you skip around in the animation. For example, consider the animation defined in the attached state file. It has a single sphere source and animates the end theta from 0 to 360 from time 0 to 0.5 and animates start theta from 0 to 360 from time 0.5 to 1.0. If you play the animation in a loop, you get a sphere that forms and disappears. However, because the tracks to not span over all time, things get messed up if you jump around in time. Try this. Go to time 1. Then go to time 0.75 and then go to time 0.25. At time 0.25 you would expect the upper hemisphere that would appear if you were playing the animation in a loop, but instead you get nothing. This is because the start theta is still at 180 instead of 0 as you would expect. | ||||||||
Attached Files | AnimateSphere.pvsm [^] (69,357 bytes) 2007-08-27 18:33 AnimateSphere.png [^] (66,925 bytes) 2007-08-27 18:34 | ||||||||
(0008688) Ken Moreland (manager) 2007-08-27 18:34 |
I have added a screen capture of the animation view so that the animation can be more easily created if the state file does not load correctly. |
(0008709) Clinton Stimpson (developer) 2007-08-28 12:49 |
Utkarsh, should this be handled by the server manager? |
(0008715) Utkarsh Ayachit (administrator) 2007-08-28 13:43 edited on: 2007-08-28 14:29 |
Yes, it should be handled in SM. I'll take a look. |
(0008724) Utkarsh Ayachit (administrator) 2007-08-28 15:41 |
If the first keyframe use added has key time > 0.0, wecreate a copy of the first keyframe and add it at time 0.0. The type of the copy is typically a BooleanKeyFrame and is defined in the xml configuration. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMKeyFrameAnimationCueManipulatorProxy.cxx,v <-- vtkSMKeyFrameAnimationCueManipulatorProxy.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMKeyFrameAnimationCueManipulatorProxy.h,v <-- vtkSMKeyFrameAnimationCueManipulatorProxy.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMKeyFrameProxy.h,v <-- vtkSMKeyFrameProxy.h new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/utilities.xml,v <-- utilities.xml new revision: 1.132; previous revision: 1.131 |
2007-08-27 18:33 | Ken Moreland | New Issue | |
2007-08-27 18:33 | Ken Moreland | File Added: AnimateSphere.pvsm | |
2007-08-27 18:34 | Ken Moreland | File Added: AnimateSphere.png | |
2007-08-27 18:34 | Ken Moreland | Note Added: 0008688 | |
2007-08-27 18:35 | Ken Moreland | Status | backlog => tabled |
2007-08-27 18:35 | Ken Moreland | Assigned To | => Clinton Stimpson |
2007-08-28 12:48 | Clinton Stimpson | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
2007-08-28 12:49 | Clinton Stimpson | Note Added: 0008709 | |
2007-08-28 13:43 | Utkarsh Ayachit | Note Added: 0008715 | |
2007-08-28 14:29 | Utkarsh Ayachit | Note Edited: 0008715 | |
2007-08-28 15:41 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-08-28 15:41 | Utkarsh Ayachit | Resolution | open => fixed |
2007-08-28 15:41 | Utkarsh Ayachit | Note Added: 0008724 | |
2007-08-29 12:18 | Ken Moreland | Status | @80@ => closed |
