0005624 | ParaView | (No Category) | public | 2007-08-30 11:40 | 2009-05-13 13:47 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005624: errors manually entering scalar values | ||||||||
Description | create a sphere source and apply elevation. edit the color map add a point in the middle, and using the Scalar Value field, set the value of the middle point outside the range (0.2 for example). It spits out an error ERROR: In .../ParaView3/Servers/Filters/vtkTransferFunctionEditorWidgetSimple1D.cxx, line 1221 vtkTransferFunctionEditorWidgetSimple1D (0x1e44420): Cannot move a transfer function node horizontally past the ones on either side of it. Can we so something like clamp the value into range, or something so we don't get those errors? When that error dialog comes up, it competes with the color scale editor and I can't see the error without closing the color scale editor. Oh, and why does the button say "Edit Color Map..." and the dialog that comes up is called "Color Scale Editor" instead of "Color Map Editor"? | ||||||||
(0016293) Utkarsh Ayachit (administrator) 2009-05-05 13:55 |
Reject scalar values not in the range for the color scale. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.57; previous revision: 1.56 |
(0016315) Alan Scott (manager) 2009-05-06 16:44 |
Tested local server. |
2007-08-30 11:40 | Clinton Stimpson | New Issue | |
2008-04-14 17:26 | Berk Geveci | Assigned To | => Berk Geveci |
2008-04-14 17:26 | Berk Geveci | Status | backlog => tabled |
2008-04-14 17:26 | Berk Geveci | Category | => 3.6 |
2009-02-16 16:02 | Ken Moreland | Assigned To | Berk Geveci => Burlen |
2009-05-05 13:54 | Utkarsh Ayachit | Assigned To | Burlen => Utkarsh Ayachit |
2009-05-05 13:55 | Utkarsh Ayachit | Note Added: 0016293 | |
2009-05-05 13:55 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-05-05 13:55 | Utkarsh Ayachit | Resolution | open => fixed |
2009-05-06 16:44 | Alan Scott | Note Added: 0016315 | |
2009-05-06 16:45 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:44 | Utkarsh Ayachit | Target Version | => 3.6 |
