0005626 | ParaView | (No Category) | public | 2007-08-30 13:06 | 2016-08-12 09:57 | ||||
Assigned To | Kyle Lutz | ||||||||
Summary | 0005626: Make array calculator operate on field data | ||||||||
Description | The array calculator should be able to operate on field data. I think there are two use cases for this. First, there should be a field data option in addition to point data and cell data that allows the calculator to create a new field data array. Second, there probably should be a way to apply a field data variable to the calculation of point or cell data. | ||||||||
Project | SDAV | ||||||||
Topic Name | array-calculator-field-data-support | ||||||||
Attached Files | ![]() | ||||||||
Relationships | ||||||||||||||||
(0014965) Ken Moreland (manager) 2009-02-16 16:03 |
If this is easy, we should do it. If not, perhaps we should just not implement it. We could try doing this with the Python calculator instead. |
(0015021) Utkarsh Ayachit (administrator) 2009-02-17 11:33 |
I've attached a partial fix patch for future work. This is a tab complicated, since FieldData doesn't have fixed length arrays so the calculator needs to be updated to handle that. Deferring this to 3.8 unless told otherwise. |
(0027566) Felipe Bordeu (reporter) 2011-10-12 04:51 edited on: 2011-12-08 08:16 |
A made this changes to add field data to the array calculator. To make this changes to work some changes in VTK are needed: please see http://paraview.org/Bug/view.php?id=12778 [^] I tested the solution for scalar fielddata only but I think it is ready for vector also: Felipe diff --git a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx index 240289c..6332008 100644 --- a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx +++ b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.cxx @@ -39,7 +39,7 @@ vtkPVArrayCalculator::~vtkPVArrayCalculator() // ---------------------------------------------------------------------------- void vtkPVArrayCalculator::UpdateArrayAndVariableNames - ( vtkDataObject * vtkNotUsed(theInputObj), vtkDataSetAttributes * inDataAttrs ) + ( vtkDataObject * vtkNotUsed(theInputObj), vtkDataSetAttributes * inDataAttrs, vtkFieldData *inDataAttrsGlobal ) { static char stringSufix[3][3] = { "_X", "_Y", "_Z" }; unsigned long mtime = this->GetMTime(); @@ -98,6 +98,50 @@ void vtkPVArrayCalculator::UpdateArrayAndVariableNames } } + + // add non-coordinate scalar and vector variables for field arrays + numberArays = inDataAttrsGlobal->GetNumberOfArrays(); // the input + for (int j = 0; j < numberArays; j ++ ) + { + vtkAbstractArray* array = inDataAttrsGlobal->GetAbstractArray(j); + const char* array_name = array->GetName(); + int numberComps = array->GetNumberOfComponents(); + + if ( numberComps == 1 ) + { + this->AddScalarVariable( array_name, array_name, 0 ); + } + else + { + for (int i = 0; i < numberComps; i ++ ) + { + if (i < 3) + { + vtksys_ios::ostringstream var_name; + var_name << array_name << stringSufix[i]; + this->AddScalarVariable(var_name.str().c_str(), array_name, i ); + } + vtksys_ios::ostringstream var_name2; + var_name2 << array_name << "_"; + if (array->GetComponentName(i)) + { + var_name2 << array->GetComponentName(i); + } + else + { + var_name2 << i; + } + this->AddScalarVariable(var_name2.str().c_str(), array_name, i ); + } + + if ( numberComps == 3 ) + { + this->AddVectorArrayName(array_name, 0, 1, 2 ); + } + } + } + // end add field arrays + assert(this->GetMTime() == mtime && "post: mtime cannot be changed in RequestData()"); static_cast<void>(mtime); // added so compiler won't complain im release mode. @@ -115,6 +159,7 @@ int vtkPVArrayCalculator::RequestData vtkGraph * graphInput = vtkGraph::SafeDownCast( input ); vtkDataSet * dsInput = vtkDataSet::SafeDownCast( input ); vtkDataSetAttributes * dataAttrs = NULL; + vtkFieldData * dataAttrsGlobal = NULL; if ( dsInput ) { @@ -129,6 +174,7 @@ int vtkPVArrayCalculator::RequestData dataAttrs = dsInput->GetCellData(); numTuples = dsInput->GetNumberOfCells(); } + dataAttrsGlobal = dsInput->GetFieldData(); } else if ( graphInput ) @@ -144,6 +190,7 @@ int vtkPVArrayCalculator::RequestData dataAttrs = graphInput->GetEdgeData(); numTuples = graphInput->GetNumberOfEdges(); } + dataAttrsGlobal = graphInput->GetFieldData(); } if ( numTuples > 0 ) @@ -153,12 +200,13 @@ int vtkPVArrayCalculator::RequestData // the scenarios where the user modifies the name of a calculator whose out- // put is the input of a (some) subsequent calculator(s) or the user changes // the input of a downstream calculator. - this->UpdateArrayAndVariableNames( input, dataAttrs ); + this->UpdateArrayAndVariableNames( input, dataAttrs, dataAttrsGlobal ); } input = NULL; dsInput = NULL; dataAttrs = NULL; + dataAttrsGlobal = NULL; graphInput = NULL; return this->Superclass::RequestData( request, inputVector, outputVector ); diff --git a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.h b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.h index 669c4f5..9ed980b 100644 --- a/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.h +++ b/ParaViewCore/VTKExtensions/vtkPVArrayCalculator.h @@ -34,6 +34,7 @@ class vtkDataObject; class vtkDataSetAttributes; +class vtkFieldData; class VTK_EXPORT vtkPVArrayCalculator : public vtkArrayCalculator { @@ -59,7 +60,8 @@ protected: // to the attributes of the input dataset. This function should be called by // RequestData() only. void UpdateArrayAndVariableNames( vtkDataObject * theInputObj, - vtkDataSetAttributes * inDataAttrs ); + vtkDataSetAttributes * inDataAttrs, + vtkFieldData * inDataAttrsGlobal ); private: vtkPVArrayCalculator( const vtkPVArrayCalculator & ); // Not implemented. void operator = ( const vtkPVArrayCalculator & ); // Not implemented. diff --git a/Qt/Components/pqCalculatorPanel.cxx b/Qt/Components/pqCalculatorPanel.cxx index 37e38bd..3558ab9 100644 --- a/Qt/Components/pqCalculatorPanel.cxx +++ b/Qt/Components/pqCalculatorPanel.cxx @@ -546,6 +546,52 @@ void pqCalculatorPanel::updateVariables(const QString& mode) this->Internal->VectorsMenu.addAction(name); } } + + // to add field arrays to the calculator + fdi = f->getInput(f->getInputPortName(0), 0)->getDataInformation() + ->GetFieldDataInformation(); + + if(!fdi) + { + return; + } + + for(int i=0; i<fdi->GetNumberOfArrays(); i++) + { + vtkPVArrayInformation* arrayInfo = fdi->GetArrayInformation(i); + if (arrayInfo->GetDataType() == VTK_STRING + || arrayInfo->GetDataType() == VTK_VARIANT ) + { + continue; + } + + int numComponents = arrayInfo->GetNumberOfComponents(); + QString name = arrayInfo->GetName(); + + for(int j=0; j<numComponents; j++) + { + if(numComponents == 1) + { + this->Internal->ScalarsMenu.addAction(name); + } + else + { + QString compName(arrayInfo->GetComponentName( j )); + QString n = name + QString( "_%1").arg( compName ); + QStringList d; + d.append(name); + d.append(QString("%1").arg(j)); + QAction* a = new QAction(n, &this->Internal->ScalarsMenu); + a->setData(d); + this->Internal->ScalarsMenu.addAction(a); + } + } + + if(numComponents == 3) + { + this->Internal->VectorsMenu.addAction(name); + } + } } void pqCalculatorPanel::variableChosen(QAction* a) |
(0029077) Kyle Lutz (viewer) 2012-08-27 13:24 |
Patch applied and pushed to ParaView stage. The topic name is 'array-calculator-field-data-support' and it depends on the VTK topic 'array-calculator-field-data-support' |
(0029120) Utkarsh Ayachit (administrator) 2012-09-03 13:30 |
merged into master, if applicable. |
(0036440) Alan Scott (manager) 2016-07-13 20:55 |
Added to Trello |
(0037531) Kitware Robot (administrator) 2016-08-12 09:57 |
2007-08-30 13:06 | Ken Moreland | New Issue | |
2007-08-30 13:06 | Ken Moreland | Relationship added | related to 0004942 |
2007-08-30 13:06 | Ken Moreland | Assigned To | => Eric Stanton |
2007-08-30 13:06 | Ken Moreland | Status | backlog => tabled |
2007-08-30 13:07 | Ken Moreland | Relationship replaced | child of 0004942 |
2008-04-15 09:31 | Berk Geveci | Assigned To | Eric Stanton => Utkarsh Ayachit |
2008-04-15 09:31 | Berk Geveci | Category | => 3.6 |
2009-02-16 16:03 | Ken Moreland | Note Added: 0014965 | |
2009-02-17 11:32 | Utkarsh Ayachit | File Added: bug.5626.patch | |
2009-02-17 11:33 | Utkarsh Ayachit | Note Added: 0015021 | |
2009-02-17 11:33 | Utkarsh Ayachit | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-04-29 08:17 | Utkarsh Ayachit | Relationship added | has duplicate 0010631 |
2010-11-26 14:14 | David Partyka | Assigned To | Utkarsh Ayachit => Robert Maynard |
2011-02-16 10:25 | Robert Maynard | Relationship added | related to 0011585 |
2011-02-16 10:25 | Robert Maynard | Target Version | 3.8 => 3.10.1 |
2011-03-31 11:24 | Utkarsh Ayachit | Target Version | 3.10.1 => 3.12 |
2011-10-12 04:51 | Felipe Bordeu | Note Added: 0027566 | |
2011-12-08 08:16 | Felipe Bordeu | Note Edited: 0027566 | |
2012-08-27 10:07 | Utkarsh Ayachit | Assigned To | Robert Maynard => Kyle Lutz |
2012-08-27 10:08 | Utkarsh Ayachit | Project | => SDAV |
2012-08-27 10:08 | Utkarsh Ayachit | Type | => incorrect functionality |
2012-08-27 10:23 | Kyle Lutz | Status | backlog => todo |
2012-08-27 13:24 | Kyle Lutz | Note Added: 0029077 | |
2012-08-27 13:24 | Kyle Lutz | Topic Name | => array-calculator-field-data-support |
2012-08-27 13:24 | Kyle Lutz | Status | todo => gatekeeper review |
2012-08-27 13:24 | Kyle Lutz | Resolution | open => fixed |
2012-09-03 13:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-03 13:30 | Utkarsh Ayachit | Note Added: 0029120 | |
2012-09-11 17:03 | Utkarsh Ayachit | Relationship replaced | has duplicate 0011585 |
2012-09-25 09:25 | Utkarsh Ayachit | Status | customer review => todo |
2015-01-02 10:43 | Utkarsh Ayachit | Fixed in Version | => 4.3 |
2016-07-13 20:55 | Alan Scott | Note Added: 0036440 | |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037531 | |
2016-08-12 09:57 | Kitware Robot | Status | todo => closed |
2016-08-12 09:57 | Kitware Robot | Fixed in Version | 4.3 => |
2016-08-12 09:57 | Kitware Robot | Resolution | fixed => moved |
