0005657 | ParaView | (No Category) | public | 2007-09-05 22:56 | 2007-09-17 19:31 | ||||
Summary | 0005657: Information tab does not update | ||||||||
Description | The information tab on the exodus reader does not update. Run ParaView. Open can.exo. Turn on all variables. Apply. Notice DISPL on Properties tab, notice DISPL on Information tab. Animate using "last frame button" Notice DISPL on Properties tab, notice DISPL on Information tab. They are different, and all of the data ranges on the information tab are wrong. | ||||||||
(0008891) Clinton Stimpson (developer) 2007-09-07 15:22 |
Fixed. /cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyInformationWidget.cxx,v <-- pqProxyInformationWidget.cxx new revision: 1.8; previous revision: 1.7 |
(0008964) Alan Scott (manager) 2007-09-12 21:25 |
Information tab issue has been fixed. Properties tab, after following the directions below, does not update. It is staying as 0-0, 0-0, 0-0 |
(0008975) Clinton Stimpson (developer) 2007-09-13 14:44 |
We decided to remove that from the Exodus panel since that info is in the information tabl. Now you can't say they're out of sync :) /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusIIPanel.cxx,v <-- pqExodusIIPanel.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExodusIIPanel.h,v <-- pqExodusIIPanel.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqExodusIIPanel.ui,v <-- pqExodusIIPanel.ui new revision: 1.7; previous revision: 1.6 |
(0009039) Alan Scott (manager) 2007-09-17 19:31 |
I LIKE IT! |
2007-09-05 22:56 | Alan Scott | New Issue | |
2007-09-07 15:22 | Clinton Stimpson | Status | backlog => tabled |
2007-09-07 15:22 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-09-07 15:22 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-07 15:22 | Clinton Stimpson | Resolution | open => fixed |
2007-09-07 15:22 | Clinton Stimpson | Note Added: 0008891 | |
2007-09-12 21:25 | Alan Scott | Note Added: 0008964 | |
2007-09-12 21:25 | Alan Scott | Status | @80@ => tabled |
2007-09-13 14:44 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-13 14:44 | Clinton Stimpson | Note Added: 0008975 | |
2007-09-17 19:31 | Alan Scott | Status | @80@ => closed |
2007-09-17 19:31 | Alan Scott | Note Added: 0009039 | |
