0005658 | ParaView | (No Category) | public | 2007-09-05 23:01 | 2009-05-13 13:59 | ||||
Summary | 0005658: Information ranges do not state that they are for the current time | ||||||||
Description | In the exodus reader, the data ranges, found on the Properties panel, as well as the Information panel, do not state that this is only for the current time step. One idea for a solution would be as follows: * On the Properties panel (on all readers), do not print out a ranges section. At the least, state that the data ranges are for the current time step. * On the Information tab, print out the time step that produced this data range. | ||||||||
(0012546) Utkarsh Ayachit (administrator) 2008-06-26 15:20 |
Added "current timestep" label just above the data array ranges in the information tab. Since the properties page no longer shows array ranges, nothing to do there. /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqProxyInformationWidget.ui,v <-- Qt/Components/Resources/UI/pqProxyInformationWidget.ui new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyInformationWidget.cxx,v <-- Qt/Components/pqProxyInformationWidget.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.h,v <-- Servers/Common/vtkPVDataInformation.h new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.cxx,v <-- Servers/Common/vtkPVDataInformation.cxx new revision: 1.54; previous revision: 1.53 |
(0012560) Alan Scott (manager) 2008-06-27 14:47 |
Tested client/server |
2007-09-05 23:01 | Alan Scott | New Issue | |
2008-04-15 09:39 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2008-04-15 09:39 | Berk Geveci | Status | backlog => tabled |
2008-04-15 09:39 | Berk Geveci | Category | => 3.4 |
2008-06-26 15:20 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-26 15:20 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-26 15:20 | Utkarsh Ayachit | Note Added: 0012546 | |
2008-06-27 14:47 | Alan Scott | Status | @80@ => closed |
2008-06-27 14:47 | Alan Scott | Note Added: 0012560 | |
