0005673 | ParaView | (No Category) | public | 2007-09-10 13:13 | 2007-09-17 18:13 | ||||
Reporter | Amy Squillacote | ||||||||
Assigned To | Dave DeMarle | ||||||||
Summary | 0005673: mouse mode entries in Edit menu | ||||||||
Description | Looking at the "Move Mode" through "SelectFrustumPoints" entries in the Edit menu, I see a few nit-picky issues. 1. For consistency he word "Mode" should either be used for all 5 entries, or not at all. 2. There should be spaces between words in SelectSurfacePoints and SelectFrustumPoints. 3. "Select Surface" and "Select Frustum" should be named "Select Surface Cells" and "Select Frustum Cells" so it's clear what type of object you're selecting (and to be consistent with "Select Surface Points" and "Select Frustum Points". | ||||||||
(0008939) Dave DeMarle (administrator) 2007-09-12 10:49 |
Fixed. I changed names to "Interact" and "Select Points/Cells On/Through". Interact action name is more generic than "move *" or "camera *" because it will be reused for other views, and I chose on/through instead of surface/frustum because more people know what through means than frustum. But feel free to change them as you see fit. /cvsroot/ParaView3/ParaView3/Applications/Client/MainWindow.ui,v <-- MainWindow.ui new revision: 1.92; previous revision: 1.91 |
2007-09-10 13:13 | Amy Squillacote | New Issue | |
2007-09-11 09:04 | Amy Squillacote | Status | backlog => tabled |
2007-09-11 09:04 | Amy Squillacote | Assigned To | => Dave DeMarle |
2007-09-12 10:49 | Dave DeMarle | Note Added: 0008939 | |
2007-09-12 10:49 | Dave DeMarle | Status | tabled => @80@ |
2007-09-12 10:49 | Dave DeMarle | Resolution | open => fixed |
2007-09-12 10:49 | Dave DeMarle | Additional Information Updated | |
2007-09-17 18:13 | Alan Scott | Status | @80@ => closed |
