0005679 | ParaView | (No Category) | public | 2007-09-11 17:21 | 2007-09-13 22:35 | ||||
Reporter | Berk Geveci | ||||||||
Summary | 0005679: Preferences dialog buttons are weird | ||||||||
Description | Apply/Reset/Close buttons are confusing. Close does not Apply so it is very easy to forget to Apply and Close. The buttons should be changed to Reset to defaults (maybe aligned to the left), Apply/Cancel/OK (in some appropriate order :-)) | ||||||||
(0008934) Clinton Stimpson (developer) 2007-09-11 17:44 |
pqOptionsDialog.ui revision 1.2 Relabeled "Close" to "Ok" Hitting that button really does apply changes. |
(0008935) Berk Geveci (administrator) 2007-09-11 17:47 |
Can you please verify that Close applies changes? On my build, it does not. Try this: * make a change to load (apply button now becomes active) * close * open again - is apply button still active? On my build it is. Also, the change to lod has not effect until I hit apply. |
(0008936) Clinton Stimpson (developer) 2007-09-11 18:30 |
Yeah, the application options dialog had that problem. Re-arranged a bit of code so options subclasses don't forget to implement this detail. /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveChartOptions.cxx,v <-- pqActiveChartOptions.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveRenderViewOptions.cxx,v <-- pqActiveRenderViewOptions.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqActiveRenderViewOptions.h,v <-- pqActiveRenderViewOptions.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Components/pqOptionsDialog.cxx,v <-- pqOptionsDialog.cxx new revision: 1.3; previous revision: 1.2 |
2007-09-11 17:21 | Berk Geveci | New Issue | |
2007-09-11 17:21 | Berk Geveci | Status | backlog => tabled |
2007-09-11 17:21 | Berk Geveci | Assigned To | => Clinton Stimpson |
2007-09-11 17:44 | Clinton Stimpson | Status | tabled => @80@ |
2007-09-11 17:44 | Clinton Stimpson | Resolution | open => fixed |
2007-09-11 17:44 | Clinton Stimpson | Note Added: 0008934 | |
2007-09-11 17:47 | Berk Geveci | Status | @80@ => @20@ |
2007-09-11 17:47 | Berk Geveci | Resolution | fixed => reopened |
2007-09-11 17:47 | Berk Geveci | Note Added: 0008935 | |
2007-09-11 18:30 | Clinton Stimpson | Status | @20@ => @80@ |
2007-09-11 18:30 | Clinton Stimpson | Resolution | reopened => fixed |
2007-09-11 18:30 | Clinton Stimpson | Note Added: 0008936 | |
2007-09-13 22:35 | Alan Scott | Status | @80@ => closed |
