0005684 | ParaView | (No Category) | public | 2007-09-11 20:42 | 2007-11-01 20:14 | ||||
Assigned To | Eric Stanton | ||||||||
Summary | 0005684: Refresh button | ||||||||
Description | We need some type of refresh button on ParaView, allowing us to reload exodus files - updating the timesteps in these files. This is needed to allow users to visualize their data as it is being created. | ||||||||
(0009020) Berk Geveci (administrator) 2007-09-17 11:27 |
Whether this is easy or not depends on the reader. For example, is there a way to make the Exodus reader to read all of the information again? I am assigning to Eric so that he can answer that question. If that works, we can probably add a button to the Exodus panel that resets the information. We will not extend this to all readers unless there is a REAL good reason to do so. |
(0009045) David Thompson (old) (reporter) 2007-09-18 02:20 |
This should be relatively simple for the reader... none of the truth tables/variable names change over time. I see two issues to resolve: 1. How does the rest of the ParaView pipeline "adjust" to the new time steps? If the number of time steps changes, any animation frames are off, the geometry/image caches must be erased, etc. 2. When using time sequence as mode shapes, it won't be the time steps that change (the ExodusII reader advertises a TIME_RANGE of [0,1] when mode shapes are on) but an "animatable parameter" that changes. Again, how will the rest of the ParaView pipeline accommodate the change? |
(0009087) Eric Stanton (reporter) 2007-09-18 13:53 |
Berk, did you want me to implement this since it looks like the exodus reader can handle it? Or was someone else going to? Doesn't matter to me. |
(0009088) Berk Geveci (administrator) 2007-09-18 13:56 |
Eric, feel free to implement this (if you have time). Please consult with Utkarsh on how to proceed. |
(0009089) Berk Geveci (administrator) 2007-09-18 13:56 |
Reminder sent to: Utkarsh Ayachit Utkarsh, Eric will do this. Can you help him if necessary? |
(0009178) Alan Scott (manager) 2007-09-19 21:14 |
I was just talking to a user, and it sounds like this is a very, very popular feature. Any idea if this will be done for 3.2 or 3.4? |
(0009179) Eric Stanton (reporter) 2007-09-19 21:22 |
That depends on when we branch. But I think with a push we can get it in to 3.2. |
(0009180) Eric Stanton (reporter) 2007-09-19 21:34 |
One challenge is going to be how to test it... |
(0009181) Alan Scott (manager) 2007-09-19 21:46 |
Obviously, don't do anything dumb that hurts the release. But, it being in 3.2 would be a BIG thing. As far as testing it, I have a user here that is creating an alegra run that will be very simple, not OUO, a few files output, write timesteps constantly for an hour or two, and that I can run. Then, I could let you try to read it as it is writing. Would that work? |
(0009182) Eric Stanton (reporter) 2007-09-19 21:47 |
Yea, that would be great. I'll let you know when its ready to be tested. |
(0009385) Eric Stanton (reporter) 2007-10-04 14:04 |
I've committed the fix to the trunk, and a patch for the 3.2 branch will be applied once next year's contract goes through. |
(0009499) Alan Scott (manager) 2007-10-17 16:02 |
I am pushing this one back until it is at least in the 3.2 branch. alan |
(0009562) Ken Moreland (manager) 2007-10-25 13:08 |
This should be in the 3.2 branch now. |
(0009611) Alan Scott (manager) 2007-11-01 20:14 |
Nice! |
2007-09-11 20:42 | Alan Scott | New Issue | |
2007-09-17 11:27 | Berk Geveci | Note Added: 0009020 | |
2007-09-17 11:27 | Berk Geveci | Status | backlog => tabled |
2007-09-17 11:27 | Berk Geveci | Assigned To | => Eric Stanton |
2007-09-18 02:20 | David Thompson (old) | Note Added: 0009045 | |
2007-09-18 13:53 | Eric Stanton | Note Added: 0009087 | |
2007-09-18 13:56 | Berk Geveci | Note Added: 0009088 | |
2007-09-18 13:56 | Berk Geveci | Note Added: 0009089 | |
2007-09-19 21:14 | Alan Scott | Note Added: 0009178 | |
2007-09-19 21:22 | Eric Stanton | Note Added: 0009179 | |
2007-09-19 21:34 | Eric Stanton | Note Added: 0009180 | |
2007-09-19 21:46 | Alan Scott | Note Added: 0009181 | |
2007-09-19 21:47 | Eric Stanton | Note Added: 0009182 | |
2007-10-04 14:04 | Eric Stanton | Status | tabled => @80@ |
2007-10-04 14:04 | Eric Stanton | Resolution | open => fixed |
2007-10-04 14:04 | Eric Stanton | Note Added: 0009385 | |
2007-10-17 16:02 | Alan Scott | Status | @80@ => @20@ |
2007-10-17 16:02 | Alan Scott | Resolution | fixed => reopened |
2007-10-17 16:02 | Alan Scott | Note Added: 0009499 | |
2007-10-25 13:08 | Ken Moreland | Status | @20@ => @80@ |
2007-10-25 13:08 | Ken Moreland | Resolution | reopened => fixed |
2007-10-25 13:08 | Ken Moreland | Note Added: 0009562 | |
2007-11-01 20:14 | Alan Scott | Status | @80@ => closed |
2007-11-01 20:14 | Alan Scott | Note Added: 0009611 | |
