0005723 | ParaView | (No Category) | public | 2007-09-17 12:20 | 2007-10-01 19:18 | ||||
Reporter | Clinton Stimpson | ||||||||
Summary | 0005723: Qt errors when viewing only spreadsheet w/ timesteps | ||||||||
Description | open can.exo into a spreadsheet view, with no other views. step through timesteps, and I get errors like QPaintEngine::setSystemRect: Should not be changed while engine is active QPaintEngine::setSystemClip: Should not be changed while engine is active which means two widgets are being painted at the same time. Its probably the progress bar being painted while painting the spreadsheet view. | ||||||||
(0009311) Utkarsh Ayachit (administrator) 2007-09-27 12:08 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.cxx,v <-- pqSpreadSheetViewModel.cxx new revision: 1.13; previous revision: 1.12 |
(0009355) Alan Scott (manager) 2007-10-01 19:18 |
Tested locally, 3.2 and head. |
2007-09-17 12:20 | Clinton Stimpson | New Issue | |
2007-09-27 11:35 | Utkarsh Ayachit | Status | backlog => tabled |
2007-09-27 11:35 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2007-09-27 12:08 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-27 12:08 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-27 12:08 | Utkarsh Ayachit | Note Added: 0009311 | |
2007-10-01 19:18 | Alan Scott | Status | @80@ => closed |
2007-10-01 19:18 | Alan Scott | Note Added: 0009355 | |
