0005744 | ParaView | (No Category) | public | 2007-09-18 17:52 | 2007-09-25 20:33 | ||||
Summary | 0005744: Selecting on an object does not select in the pipeline browser | ||||||||
Description | When you select cells or points of an object in a 3D view, the object associated with that selection should be selected in the pipeline browser. If it is not, that could be confusing when you want to add the Extract Selections filter. | ||||||||
(0009187) Utkarsh Ayachit (administrator) 2007-09-20 14:24 |
When selection changes, we update the servermanager model selection which determines which sources get highlighted in the pipeline browser. /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionManager.cxx,v <-- pqSelectionManager.cxx new revision: 1.59; previous revision: 1.58 |
2007-09-18 17:52 | Ken Moreland | New Issue | |
2007-09-20 13:47 | Berk Geveci | Status | backlog => tabled |
2007-09-20 13:47 | Berk Geveci | Assigned To | => Utkarsh Ayachit |
2007-09-20 14:24 | Utkarsh Ayachit | Status | tabled => @80@ |
2007-09-20 14:24 | Utkarsh Ayachit | Resolution | open => fixed |
2007-09-20 14:24 | Utkarsh Ayachit | Note Added: 0009187 | |
2007-09-25 20:33 | Alan Scott | Status | @80@ => closed |
