0005861 | ParaView | (No Category) | public | 2007-10-10 15:26 | 2009-05-13 13:45 | ||||
Summary | 0005861: Specify histogram bin range | ||||||||
Description | Right now the histogram looks at the range of the scalar it is making a histogram for and then creates bins that span that range. That is a good default, but not always the desired behavior. For example, if I make a histogram for data that changes over time, the range and size of the bins will change every time change. There should be an option in the histogram filter to specify the range of the bins. | ||||||||
(0015025) Utkarsh Ayachit (administrator) 2009-02-17 12:02 |
Added interface to specify custom bin ranges. /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPExtractHistogram.cxx,v <-- Servers/Filters/vtkPExtractHistogram.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.cxx,v <-- Servers/Filters/vtkExtractHistogram.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.h,v <-- Servers/Filters/vtkExtractHistogram.h new revision: 1.10; previous revision: 1.9 |
(0015045) Utkarsh Ayachit (administrator) 2009-02-17 13:54 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.326; previous revision: 1.325 |
(0015194) Alan Scott (manager) 2009-02-18 19:06 |
Nope, it now hangs, client/remote server with multiple processes. I am using 6 pvservers. * Create a sphere source. * Data Analysis/ Histogram. Apply. All is well. * Select "Use Custom Bin Ranges". Type -0.1 in the left (min) entry box. Apply. ParaView will never come back. |
(0015888) Utkarsh Ayachit (administrator) 2009-04-01 15:44 |
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.cxx,v <-- Servers/Filters/vtkExtractHistogram.cxx new revision: 1.25; previous revision: 1.24 |
(0015889) Utkarsh Ayachit (administrator) 2009-04-01 16:03 |
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.cxx,v <-- Servers/Filters/vtkExtractHistogram.cxx new revision: 1.26; previous revision: 1.25 |
(0015910) Alan Scott (manager) 2009-04-03 15:37 |
Tested client/ remote server. |
2007-10-10 15:26 | Ken Moreland | New Issue | |
2008-04-15 10:32 | Berk Geveci | Status | backlog => @30@ |
2008-04-15 10:32 | Berk Geveci | Category | 3.4 => 3.6 |
2009-02-16 17:10 | Ken Moreland | Status | @30@ => tabled |
2009-02-16 17:10 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
2009-02-17 12:02 | Utkarsh Ayachit | Note Added: 0015025 | |
2009-02-17 12:02 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-02-17 12:02 | Utkarsh Ayachit | Resolution | open => fixed |
2009-02-17 13:54 | Utkarsh Ayachit | Note Added: 0015045 | |
2009-02-18 19:06 | Alan Scott | Note Added: 0015194 | |
2009-02-18 19:06 | Alan Scott | Status | @80@ => @20@ |
2009-02-18 19:06 | Alan Scott | Resolution | fixed => reopened |
2009-04-01 15:44 | Utkarsh Ayachit | Note Added: 0015888 | |
2009-04-01 16:03 | Utkarsh Ayachit | Note Added: 0015889 | |
2009-04-01 16:03 | Utkarsh Ayachit | Status | @20@ => @80@ |
2009-04-01 16:03 | Utkarsh Ayachit | Resolution | reopened => fixed |
2009-04-03 15:37 | Alan Scott | Note Added: 0015910 | |
2009-04-03 15:37 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:45 | Utkarsh Ayachit | Target Version | => 3.6 |
