0005923 | ParaView | (No Category) | public | 2007-10-22 14:58 | 2007-11-28 19:22 | ||||
Reporter | David Karelitz | ||||||||
Summary | 0005923: Calculator function is not reloaded with Load State | ||||||||
Description | When you have a calculator as part of saved state, the function is not reloaded in the UI when Load State is performed. The computed variable is initially correct and available, but hitting apply causes the empty formula to be applied | ||||||||
(0009644) Clinton Stimpson (developer) 2007-11-06 12:21 |
This happend if attribute mode was cell data (not point data). /cvsroot/ParaView3/ParaView3/Qt/Components/pqCalculatorPanel.cxx,v <-- pqCalculatorPanel.cxx new revision: 1.18; previous revision: 1.17 |
(0009784) Alan Scott (manager) 2007-11-28 19:22 |
Tested locally only. |
2007-10-22 14:58 | David Karelitz | New Issue | |
2007-11-06 12:12 | Clinton Stimpson | Status | backlog => tabled |
2007-11-06 12:12 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-11-06 12:21 | Clinton Stimpson | Status | tabled => @80@ |
2007-11-06 12:21 | Clinton Stimpson | Resolution | open => fixed |
2007-11-06 12:21 | Clinton Stimpson | Note Added: 0009644 | |
2007-11-28 19:22 | Alan Scott | Status | @80@ => closed |
2007-11-28 19:22 | Alan Scott | Note Added: 0009784 | |
