0006095 | ParaView | (No Category) | public | 2007-11-29 11:15 | 2008-04-15 18:23 | ||||
Reporter | David Karelitz | ||||||||
Priority | normal | Severity | major | Reproducibility | sometimes | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0006095: Offscreen rendering high-res movies with multiple views sometimes produces black views | ||||||||
Description | While rendering a 5-view, 1000 timestep, high res movie (7680x4096), sometimes some of the views are black. It first happened at frame 167 and 168 where 2 adjacent views were black. This was with the ParaView trunk from 11/28 running locally | ||||||||
(0011255) Ken Moreland (manager) 2008-04-10 09:59 |
I just tried to reproduce this bug on the CVS trunk. I set up an animation of a sphere where its start theta moved from 0 to 360. I wrote out an animation of 1000 png files at the resolution specified here (7680x4096). I looked at all the frames and none of them turned black. I believe this bug has already been fixed. Please try it again on the current CVS build. If you still get the problem, send more details: platform used, data used, animation setup. |
(0011378) Alan Scott (manager) 2008-04-15 18:23 |
Ken's test is good enough for me. |
2007-11-29 11:15 | David Karelitz | New Issue | |
2008-04-10 09:59 | Ken Moreland | Status | backlog => @80@ |
2008-04-10 09:59 | Ken Moreland | Resolution | open => unable to reproduce |
2008-04-10 09:59 | Ken Moreland | Assigned To | => Ken Moreland |
2008-04-10 09:59 | Ken Moreland | Note Added: 0011255 | |
2008-04-15 18:23 | Alan Scott | Status | @80@ => closed |
2008-04-15 18:23 | Alan Scott | Note Added: 0011378 | |
