0006098 | ParaView | (No Category) | public | 2007-11-29 12:46 | 2007-12-05 18:33 | ||||
Priority | low | Severity | minor | Reproducibility | always | ||||
Summary | 0006098: Line source cross hairs should be visible | ||||||||
Description | The cross hairs should always be visible. Open ParaView, XP Sources/ Line. Apply. The y and z axis cross hairs have a length of zero. They should have some minimum length. Next, click the Z axis button. The cross hairs never reset - you are left with the X axis cross hair only. If you undo "show center", then redo "show center", it resets and only the Z axis cross hair shows. Hit Y axis. Wrong again. | ||||||||
(0009801) Clinton Stimpson (developer) 2007-11-30 13:01 |
Simple fix. /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- pqRenderView.cxx new revision: 1.26; previous revision: 1.25 |
(0009828) Alan Scott (manager) 2007-12-04 19:57 |
Clint, The line source cross hairs have a funny feeling now. Is this what we want? * Source/Line/Apply. * Y Axis. Apply. Notice the cross hairs. * Turn off show center, turn on show center. The cross hairs change. Shouldn't the cross hairs change any time that the line is moved (such as Y axis?) alan |
(0009837) Clinton Stimpson (developer) 2007-12-05 13:23 |
The current (and old) behavior is to update the cross hairs when its visibility changes, the camera is reset, or the center of rotation has changed. I'm not sure if its supposed to update everytime a data set changes. |
(0009838) Clinton Stimpson (developer) 2007-12-05 13:33 |
marking as fixed. |
(0009839) Alan Scott (manager) 2007-12-05 18:33 |
Tested local server. |
2007-11-29 12:46 | Alan Scott | New Issue | |
2007-11-30 13:01 | Clinton Stimpson | Status | backlog => @80@ |
2007-11-30 13:01 | Clinton Stimpson | Resolution | open => fixed |
2007-11-30 13:01 | Clinton Stimpson | Assigned To | => Clinton Stimpson |
2007-11-30 13:01 | Clinton Stimpson | Note Added: 0009801 | |
2007-12-04 19:57 | Alan Scott | Status | @80@ => @20@ |
2007-12-04 19:57 | Alan Scott | Resolution | fixed => reopened |
2007-12-04 19:57 | Alan Scott | Note Added: 0009828 | |
2007-12-05 13:23 | Clinton Stimpson | Note Added: 0009837 | |
2007-12-05 13:33 | Clinton Stimpson | Status | @20@ => @80@ |
2007-12-05 13:33 | Clinton Stimpson | Resolution | reopened => fixed |
2007-12-05 13:33 | Clinton Stimpson | Note Added: 0009838 | |
2007-12-05 18:33 | Alan Scott | Status | @80@ => closed |
2007-12-05 18:33 | Alan Scott | Note Added: 0009839 | |
