| 0006129 | ParaView | (No Category) | public | 2007-12-05 13:49 | 2015-01-11 08:30 | ||||
| Reporter | Kent Eschenberg | ||||||||
| Assigned To | Kyle Lutz | ||||||||
| Priority | high | Severity | feature | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
| Summary | 0006129: Allow Opacity Settings for All | ||||||||
| Description | The opacity of the control points in the colormap editor cannot be set interactively or in a file. I have been told this is enabled only for volume rendering. It should be enabled in all cases. For example, using a modification of ParaView 2.6.1, we used custom colormaps to color data on a plane so that a second plane could show through where the scalars were small. The second plane was a full-color USGS elevation relief map. The result was very effective and I see no good way to do this without the requested feature. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 6129_translucent_polygonal_rendering | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0028409) Alan Scott (manager) 2012-03-30 02:36 |
This would be a really nice feature for 4.0. Lets try to get it in if possible. Marking as high, since it is a showstopper for LLNL users, and would be very valuable for Sandia. |
(0028948) Kyle Lutz (viewer) 2012-07-26 09:38 |
Merge topic '6129_translucent_polygonal_rendering' into next d1905d0 Fix bug with opacity function and volume rendering |
(0028959) Utkarsh Ayachit (administrator) 2012-07-27 14:43 |
merged into master, if applicable. |
(0028966) Alan Scott (manager) 2012-08-01 14:09 |
Very nice! Tested windows, local server, master. |
| Notes |
| Issue History | |||
| 2007-12-05 13:49 | Kent Eschenberg | New Issue | |
| 2008-04-08 15:37 | Ken Moreland | Category | => 3.6 |
| 2009-02-16 17:36 | Ken Moreland | Category | 3.6 => 3.8 |
| 2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
| 2010-11-26 14:03 | David Partyka | Assigned To | => Utkarsh Ayachit |
| 2010-11-26 14:03 | David Partyka | Status | backlog => tabled |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| 2012-03-29 13:10 | Utkarsh Ayachit | Status | expired => backlog |
| 2012-03-29 13:10 | Utkarsh Ayachit | Resolution | open => reopened |
| 2012-03-29 13:10 | Utkarsh Ayachit | Project | => TBD |
| 2012-03-29 13:10 | Utkarsh Ayachit | Type | => incorrect functionality |
| 2012-03-29 13:10 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2012-03-30 02:36 | Alan Scott | Project | TBD => Sandia |
| 2012-03-30 02:36 | Alan Scott | Type | incorrect functionality => feature |
| 2012-03-30 02:36 | Alan Scott | Note Added: 0028409 | |
| 2012-03-30 02:36 | Alan Scott | Priority | normal => high |
| 2012-03-30 02:37 | Alan Scott | Status | backlog => todo |
| 2012-05-31 10:23 | Utkarsh Ayachit | Status | todo => backlog |
| 2012-05-31 10:25 | Utkarsh Ayachit | Status | backlog => todo |
| 2012-07-11 11:18 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Kyle Lutz |
| 2012-07-11 12:03 | Kyle Lutz | Status | todo => active development |
| 2012-07-26 09:38 | Kyle Lutz | Topic Name | => 6129_translucent_polygonal_rendering |
| 2012-07-26 09:38 | Kyle Lutz | Note Added: 0028948 | |
| 2012-07-26 09:38 | Kyle Lutz | Status | active development => gatekeeper review |
| 2012-07-26 09:38 | Kyle Lutz | Resolution | reopened => fixed |
| 2012-07-27 14:42 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-07-27 14:43 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-07-27 14:43 | Utkarsh Ayachit | Note Added: 0028959 | |
| 2012-08-01 14:09 | Alan Scott | Note Added: 0028966 | |
| 2012-08-01 14:09 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| 2015-01-11 08:29 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 9b4f332b |
| 2015-01-11 08:29 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 0acfbe83 |
| 2015-01-11 08:30 | Kyle Lutz | Source_changeset_attached | => ParaView master c9ed6df5 |
| Issue History |
