0006146 | ParaView | (No Category) | public | 2007-12-11 10:09 | 2008-03-07 07:56 | ||||
Reporter | David Karelitz | ||||||||
Assigned To | |||||||||
Summary | 0006146: (MARS-normal) Calculator causes upstream filters/readers to re-execute | ||||||||
Description | When you apply a calculator filter (after accepting the changes from any upstream filters), the calculator causes all the upstream filters to re-execute. This may be related to the bug about issues when the first timestep in a file is not 0, but I'm not positive | ||||||||
(0009859) David Karelitz (reporter) 2007-12-11 12:29 |
The problem seems to be with CellToPoint. Just about anything causes it to re-execute. |
(0010181) David Karelitz (reporter) 2008-01-17 17:54 |
This doesn't look like a bug anymore. It seems like it was related to compute normals on contour causing ghost cells to be needed. |
2007-12-11 10:09 | David Karelitz | New Issue | |
2007-12-11 12:29 | David Karelitz | Note Added: 0009859 | |
2008-01-17 17:54 | David Karelitz | Status | backlog => closed |
2008-01-17 17:54 | David Karelitz | Note Added: 0010181 | |
2008-01-17 17:54 | David Karelitz | Resolution | open => fixed |
2008-03-07 07:56 | Berk Geveci | Target Version | => MARS |
