0006217ParaView(No Category)public2008-01-04 16:242009-05-13 13:46
ReporterDavid Karelitz
Assigned ToKen Moreland
PrioritynormalSeverityfeatureReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version3.6Fixed in Version
Summary0006217: (MARS-low) Add tickmarks to scalar bar widget
DescriptionThe scalar bar widget should have tick marks that indicate whether it's showing a linear or log-scale
TagsNo tags attached.
Project
Topic Name
Type
Attached Filespng file icon ScalarBarTicMockup.png [^] (181,461 bytes) 2008-04-17 17:12
png file icon niceTics.png [^] (12,199 bytes) 2008-04-22 10:14
tgz file icon ticmarks.tgz [^] (1,540 bytes) 2008-04-22 10:14
 Relationships
  Notes
(0011286)
Ken Moreland (manager)
2008-04-14 14:10
I'm hesitant to implement this. I can think of multiple approaches, but they all have issues.
1. Divide the region between labels evenly and place tick marks there. Unfortunately, this means the value at each tick has no obvious value. This can be especially confusing if the range (or its log) is divisible by 10 but the tick marks do not line up in decimal increments.
2. Ignore labels and place ticks at regions at some decimal length. This means that the ticks will not line up with the labels and create even more confusion.
3. Adjust the labels so that fall on tick marks lined up with decimal increments. This issue with that is that the labels no longer reflect the actual range of the data (or at least the mapping), which I feel is an important cue. You could fix that by...
4. setting the top and bottom labels at the top and bottom of the range but adjusting all the mid labels to the tick marks. Ignoring the issue with the top and bottom tick marks lining up, there is still an issue with the number of labels being used. Assuming the range size is at (or close to) some multiple of 10, your choices for the number of ticks (that line up on decimals) are 2, 5, or some multiple of those. 2 is too few, you basically get a middle value and that's it. 5 is too many; the font would have to be too small to see on anything but a full screen image, and you don't even get the middle value.
(0011418)
David Thompson (old) (reporter)
2008-04-17 17:14
The attached picture has tic marks rendered in black with additional yellow marks showing the location of the text label values. The top scalar bar is logarithmic. The lower is linear.
(0011475)
2008-04-22 10:18
Dave T. has come up with an even better solution for the tickmarks. The idea is to put the range labels above and below the bar and then scale the tickmarks such that they have nice spacing throughout the rest of the scalar bar (see the niceTics.png attachment). He has also made several algorithms to determine the appropriate spacing, written as readable MATLAB/Octave files, attached in tickmarks.tgz. There are also some plotting routines in there.
(0014175)
2008-11-25 09:29
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.cxx,v <-- Servers/Filters/vtkPVScalarBarActor.cxx
new revision: 1.6; previous revision: 1.5
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVScalarBarActor.h,v <-- Servers/Filters/vtkPVScalarBarActor.h
new revision: 1.4; previous revision: 1.3
/cvsroot/ParaView3/ParaViewData/Baseline/ColorEditor1.png,v <-- ColorEditor1.png
new revision: 1.3; previous revision: 1.2
/cvsroot/ParaView3/ParaViewData/Baseline/ExtractLevel.png,v <-- ExtractLevel.png
/cvsroot/ParaView3/ParaViewData/Baseline/ProxyPropertyLinks.png,v <-- ProxyPropertyLinks.png
(0014296)
Alan Scott (manager)
2008-12-04 21:59
Close, but not quite.
The tick marks should follow the color of the Color Scale Editor/ Color Legend/ Labels / Color, if possible. If this is hard, the current ticks are actually a pretty good color (they show OK on a default, white or black background).
(0015030)
2009-02-17 13:12
Tick colors now (closely) follow label colors (instead of the widget color, which nothing was using).
(0015121)
2009-02-17 21:48
Excellent. Tested local server.
 Issue History
2008-01-04 16:24 David Karelitz New Issue
2008-03-07 07:56 Berk Geveci Target Version => MARS
2008-03-07 08:03 Berk Geveci Category Development => 3.4
2008-04-09 16:12 Ken Moreland Status backlog => tabled
2008-04-09 16:12 Ken Moreland Assigned To => Ken Moreland
2008-04-14 14:10 Ken Moreland Note Added: 0011286
2008-04-17 17:12 David Thompson (old) File Added: ScalarBarTicMockup.png
2008-04-17 17:14 David Thompson (old) Note Added: 0011418
2008-04-22 10:14 Ken Moreland File Added: niceTics.png
2008-04-22 10:14 Ken Moreland File Added: ticmarks.tgz
2008-04-22 10:18 Ken Moreland Note Added: 0011475
2008-05-29 13:26 Berk Geveci Category 3.4 => 3.6
2008-11-25 09:29 Ken Moreland Note Added: 0014175
2008-11-25 09:29 Ken Moreland Status tabled => @80@
2008-11-25 09:29 Ken Moreland Resolution open => fixed
2008-12-04 21:59 Alan Scott Note Added: 0014296
2008-12-04 21:59 Alan Scott Status @80@ => @20@
2008-12-04 21:59 Alan Scott Resolution fixed => reopened
2009-02-17 13:12 Ken Moreland Note Added: 0015030
2009-02-17 13:12 Ken Moreland Status @20@ => @80@
2009-02-17 13:12 Ken Moreland Resolution reopened => fixed
2009-02-17 21:48 Alan Scott Note Added: 0015121
2009-02-17 21:48 Alan Scott Status @80@ => closed
2009-05-13 13:46 Utkarsh Ayachit Target Version MARS => 3.6
