0006228 | ParaView | (No Category) | public | 2008-01-09 20:50 | 2008-02-20 16:04 | ||||
Assigned To | David Thompson (old) | ||||||||
Summary | 0006228: Exodus reader needs to be able to handle 2d cylindrical axisymmetric coordinates. | ||||||||
Description | My user explains the problem as follows: > ALEGRA can also run in cylindrical axisymmetric (r-z) coordinates. If > you find that there are 2 coordinate dimensions, could you look for > trailing {R,Z} in addition to {X,Y}? For whatever reason, we sometimes > write r-z vector components DISPLX, DISPLY and e.g. B_R, B_Z in the same exodus > file. | ||||||||
(0010148) David Thompson (old) (reporter) 2008-01-14 17:33 |
/cvsroot/ParaView3/ParaView3/VTK/Hybrid/vtkExodusIIReader.cxx,v <-- vtkExodusIIReader.cxx new revision: 1.48; previous revision: 1.47 Array gloms should work on consecutive variables that end with "_R" and then "_Z". Note that unlike other vectors (that need only end in "X", "Y", and "Z"), this requires an underscore to prevent other variable names from matching. |
(0010606) Alan Scott (manager) 2008-02-20 16:04 |
I believe that this one is fixed. I do not have a good way to test it. alan |
2008-01-09 20:50 | Alan Scott | New Issue | |
2008-01-14 17:33 | David Thompson (old) | Status | backlog => @80@ |
2008-01-14 17:33 | David Thompson (old) | Resolution | open => fixed |
2008-01-14 17:33 | David Thompson (old) | Assigned To | => David Thompson (old) |
2008-01-14 17:33 | David Thompson (old) | Note Added: 0010148 | |
2008-02-20 16:04 | Alan Scott | Status | @80@ => closed |
2008-02-20 16:04 | Alan Scott | Note Added: 0010606 | |
