0006307 | ParaView | (No Category) | public | 2008-02-07 16:31 | 2009-05-13 13:59 | ||||
Priority | normal | Severity | minor | Reproducibility | random | ||||
Summary | 0006307: Pipeline not always updating when time is shifted | ||||||||
Description | It has been brought to my attention that in certain circumstances the pipeline does not call algorithms multiple times when different time steps are requested of them. I see this problem most often when the output of an algorithm is attached to time shift scale filters (each with a different shift) and the output of those is combined into a multi-input filter. | ||||||||
Additional Information | I have uploaded an example state file demonstrating the problem. Notice that there is two different colored blocks, and when you hit play the white one should move and then the purple one moves. Instead, nothing happens for the first part of the animation and then they both move for the second part of the animation. If you disable the visibility of the programmable filter, the animation occurs as expected. This behavior is intermittent, but seems to be reproducible right after you load the state file. | ||||||||
Attached Files | ![]() ![]() | ||||||||
Relationships | ||||||
(0010427) Ken Moreland (manager) 2008-02-07 16:32 |
I uploaded a second state file that is the same as the first except that the multi-input filter is the group filter. This is to rule out any issues with the programmable filter. |
(0013005) Berk Geveci (administrator) 2008-08-14 08:34 |
This must have been fixed with some other changes. I cannot reproduce it. Note that I had to make some fixes to make sure that the state file worked with 3.3. I also updated the state file because the python filter used old temporal dataset API. |
(0013029) Alan Scott (manager) 2008-08-14 17:51 |
When I try to open either of these state files, it crashes ParaView. Is it that this state file is old, or is this a bug? Thanks! |
(0013037) Berk Geveci (administrator) 2008-08-15 11:40 |
You are fast. There was bug introduced yesterday. It is now fixed. |
(0013097) Alan Scott (manager) 2008-08-19 20:15 |
NICE TEST!!! Tested client/server. |
2008-02-07 16:31 | Ken Moreland | New Issue | |
2008-02-07 16:31 | Ken Moreland | File Added: TimeShiftTest1.pvsm | |
2008-02-07 16:31 | Ken Moreland | File Added: TimeShiftTest2.pvsm | |
2008-02-07 16:32 | Ken Moreland | Note Added: 0010427 | |
2008-04-09 18:25 | Ken Moreland | Status | backlog => tabled |
2008-04-09 18:25 | Ken Moreland | Assigned To | => Berk Geveci |
2008-08-14 08:32 | Berk Geveci | File Deleted: TimeShiftTest1.pvsm | |
2008-08-14 08:33 | Berk Geveci | File Added: TimeShiftTest1.pvsm | |
2008-08-14 08:34 | Berk Geveci | Status | tabled => @80@ |
2008-08-14 08:34 | Berk Geveci | Resolution | open => unable to reproduce |
2008-08-14 08:34 | Berk Geveci | Note Added: 0013005 | |
2008-08-14 17:51 | Alan Scott | Status | @80@ => @20@ |
2008-08-14 17:51 | Alan Scott | Resolution | unable to reproduce => reopened |
2008-08-14 17:51 | Alan Scott | Note Added: 0013029 | |
2008-08-15 11:40 | Berk Geveci | Status | @20@ => @80@ |
2008-08-15 11:40 | Berk Geveci | Resolution | reopened => fixed |
2008-08-15 11:40 | Berk Geveci | Note Added: 0013037 | |
2008-08-19 20:15 | Alan Scott | Status | @80@ => closed |
2008-08-19 20:15 | Alan Scott | Note Added: 0013097 | |
2008-11-24 18:52 | Ken Moreland | Relationship added | related to 0008156 |
