0006452 | ParaView | (No Category) | public | 2008-02-27 08:27 | 2009-05-13 13:59 | ||||
Summary | 0006452: Camera link zoom does not work with parallel projection | ||||||||
Description | If you have parallel projection on and link the camera of two views together, then the zoom feature is not linked between them. | ||||||||
Relationships | ||||||
(0011814) Utkarsh Ayachit (administrator) 2008-05-12 10:48 |
Zoom is now linked when parallel projection is on on all linked views. Zoom will not work in views with parallel and perspective projection are linked together. This is because vtkCamera uses different parameters for the two projections. --------------------------------------- commitid: TPKMtcon1P0oxG2t; --------------------------------------- /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.285; previous revision: 1.284 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCameraLink.cxx,v <-- Servers/ServerManager/vtkSMCameraLink.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCameraProxy.cxx,v <-- Servers/ServerManager/vtkSMCameraProxy.cxx new revision: 1.4; previous revision: 1.3 |
(0011878) Alan Scott (manager) 2008-05-13 19:09 |
Looks great! Tested local ParaView |
2008-02-27 08:27 | Ken Moreland | New Issue | |
2008-04-09 19:07 | Ken Moreland | Status | backlog => tabled |
2008-04-09 19:07 | Ken Moreland | Assigned To | => Berk Geveci |
2008-05-08 14:02 | Berk Geveci | Assigned To | Berk Geveci => Clinton Stimpson |
2008-05-08 14:02 | Berk Geveci | Assigned To | Clinton Stimpson => Utkarsh Ayachit |
2008-05-12 10:48 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-05-12 10:48 | Utkarsh Ayachit | Resolution | open => fixed |
2008-05-12 10:48 | Utkarsh Ayachit | Note Added: 0011814 | |
2008-05-13 19:09 | Alan Scott | Status | @80@ => closed |
2008-05-13 19:09 | Alan Scott | Note Added: 0011878 | |
2008-05-16 16:57 | Utkarsh Ayachit | Relationship added | related to 0006785 |
