0000646 | ParaView | (No Category) | public | 2004-03-02 21:44 | 2009-12-09 14:49 | ||||
Reporter | Andrew Maclean | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0000646: Static Linking Problem with VTK. | ||||||||
Description | I get this error: paraview error LNK2019: unresolved external symbol _main referenced in function _mainCRTStartup When building the release version using VC7.1 (.NET 2003). I think, but I am not sure, that it relates to the static building of the VTK libraries used when the default Paraview build happens. I use CMake and just accept all the suggested default parameters. | ||||||||
(0000873) Amy Squillacote (reporter) 2004-04-15 09:50 |
What version of ParaView did this happen with? I just tried a fresh build from the CVS tree, accepting all the defaults from CMake, and ParaView built fine. |
(0000899) Amy Squillacote (reporter) 2004-04-16 09:16 |
This seems to work now, and the source tree has been completely reorganized since this bug was reported. |
2007-08-04 15:58 | Berk Geveci | Assigned To | user18 => Berk Geveci |
2007-08-04 15:58 | Berk Geveci | Priority | urgent => high |
2007-08-04 15:58 | Berk Geveci | Severity | minor => major |
2007-08-04 15:58 | Berk Geveci | Status | backlog => closed |
2007-08-04 15:58 | Berk Geveci | Resolution | won't fix => unable to reproduce |
2007-08-04 15:58 | Berk Geveci | Summary | Goodsite => Static Linking Problem with VTK. |
2007-08-04 15:58 | Berk Geveci | Note Deleted: 0008262 | |
2007-08-04 15:58 | Berk Geveci | Project | @4@ => @3@ |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
