0006482 | ParaView | (No Category) | public | 2008-02-29 16:10 | 2008-04-15 12:49 | ||||
Reporter | Robert Maynard | ||||||||
Assigned To | |||||||||
Platform | Apple Mac | OS | OS X | OS Version | 10.4.10 | ||||
Summary | 0006482: Python Servermanager mulitple source objects with same name | ||||||||
Description | if a user names two or more pipeline objects with the same name, the source proxies group will overwrite the dictonary entry. The solution seems to be is to before adding an entry to the source dict, first make sure that will not clobber an existing name, and if so rename the source entry. This problem does not happen in the representations as they are automatically named. | ||||||||
Steps To Reproduce | Load same file twice into paraview Open up Python Shell pxm = servermanager.ProxyManager() source = pxm.GetProxiesInGroup('sources') rep = pxm.GetProxiesInGroup('representations') print len(source), len(rep) #should print 1 2 | ||||||||
(0010671) Robert Maynard (developer) 2008-02-29 17:14 |
I was able to add a work around to MIRARCO's own version by changing the GetProxiesInGroup method inside the servermanager.py to the following code. It is a little rough and the string join should be used rather then the + method but it works so far in testing def GetProxiesInGroup(self, groupname, connection=None): """Returns a map of proxies in a particular group. If connection is not None, then only those proxies in the group that are on the particular connection are returned. """ proxies = {} iter = self.NewGroupIterator(groupname) for aProxy in iter: temp = iter.GetKey() name = temp counter = 1 while name in proxies: name = temp +'_' +str(counter) counter+=1 proxies[name] = aProxy; return proxies |
(0011336) Berk Geveci (administrator) 2008-04-15 12:49 |
This is not true. The proxy manager dictionary uses the proxy id as well as the name in the key. Use vtkSMProxyManager::GetProxies() when there are multiple proxies with the same name. |
2008-02-29 16:10 | Robert Maynard | New Issue | |
2008-02-29 17:14 | Robert Maynard | Note Added: 0010671 | |
2008-04-15 12:49 | Berk Geveci | Status | backlog => closed |
2008-04-15 12:49 | Berk Geveci | Note Added: 0011336 | |
2008-04-15 12:49 | Berk Geveci | Resolution | open => no change required |
