0006529 | ParaView | (No Category) | public | 2008-03-06 14:28 | 2009-05-13 13:59 | ||||
Reporter | Berk Geveci | ||||||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006529: Partial arrays should be supported in filters | ||||||||
Description | Partial arrays should be supported in filters | ||||||||
(0012214) Utkarsh Ayachit (administrator) 2008-06-03 10:51 |
Partial arrays refer to arrays that are present in some blocks and not in all blocks. We want to look at supporting at least the major filters. All combo boxes including color-by combo should mark all partial arrays as "partial" or something. The filters may still throw errors for missing partial arrays, but they should not crash. |
(0013003) Utkarsh Ayachit (administrator) 2008-08-13 15:42 |
The color-chooser now marks partial arrays with '(partial)' suffix. /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- Qt/Components/pqDisplayColorWidget.cxx new revision: 1.36; previous revision: 1.35 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.h,v <-- Qt/Components/pqDisplayColorWidget.h new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.cxx,v <-- Qt/Core/pqPipelineRepresentation.cxx new revision: 1.31; previous revision: 1.30 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPipelineRepresentation.h,v <-- Qt/Core/pqPipelineRepresentation.h new revision: 1.11; previous revision: 1.10 |
(0013013) Utkarsh Ayachit (administrator) 2008-08-14 12:51 |
Marked partial arrays on array selection widget shown in Threshold panel (among others) /cvsroot/ParaView3/ParaView3/Qt/Components/pqFieldSelectionAdaptor.cxx,v <-- Qt/Components/pqFieldSelectionAdaptor.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSMAdaptor.cxx,v <-- Qt/Core/pqSMAdaptor.cxx new revision: 1.41; previous revision: 1.40 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSMAdaptor.h,v <-- Qt/Core/pqSMAdaptor.h new revision: 1.14; previous revision: 1.13 |
(0013034) Utkarsh Ayachit (administrator) 2008-08-15 08:51 |
Most of the array selection combos that use the pqComboBoxDomain now mark partial arrays. /cvsroot/ParaView3/ParaView3/Qt/Components/pqComboBoxDomain.cxx,v <-- Qt/Components/pqComboBoxDomain.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- Qt/Components/pqNamedWidgets.cxx new revision: 1.50; previous revision: 1.49 |
(0013277) Utkarsh Ayachit (administrator) 2008-09-03 13:30 |
Rest will be done on case-by-case basis. |
(0013360) Alan Scott (manager) 2008-09-08 16:18 |
Internal to ParaView. Not tested. |
2008-03-06 14:28 | Berk Geveci | New Issue | |
2008-03-06 14:42 | Berk Geveci | Target Version | => Multi-block support |
2008-03-06 14:50 | Berk Geveci | Status | backlog => tabled |
2008-03-06 14:50 | Berk Geveci | Assigned To | => Berk Geveci |
2008-06-03 10:44 | Utkarsh Ayachit | Assigned To | Berk Geveci => Burlen |
2008-06-03 10:51 | Utkarsh Ayachit | Note Added: 0012214 | |
2008-08-07 13:18 | Utkarsh Ayachit | Assigned To | Burlen => Utkarsh Ayachit |
2008-08-13 15:42 | Utkarsh Ayachit | Note Added: 0013003 | |
2008-08-14 12:51 | Utkarsh Ayachit | Note Added: 0013013 | |
2008-08-15 08:51 | Utkarsh Ayachit | Note Added: 0013034 | |
2008-09-03 13:30 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-09-03 13:30 | Utkarsh Ayachit | Resolution | open => fixed |
2008-09-03 13:30 | Utkarsh Ayachit | Note Added: 0013277 | |
2008-09-08 16:18 | Alan Scott | Status | @80@ => closed |
2008-09-08 16:18 | Alan Scott | Note Added: 0013360 | |
2009-05-13 13:58 | Utkarsh Ayachit | Target Version | Multi-block support => 3.4 |
