0006532 | ParaView | (No Category) | public | 2008-03-06 14:30 | 2016-08-12 09:57 | ||||
Reporter | Berk Geveci | ||||||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006532: Add ghost level support to composite datasets | ||||||||
Description | Add ghost level support to composite datasets | ||||||||
(0015042) Ken Moreland (manager) 2009-02-17 13:40 |
Do you mean ghost cells in one block that really belongs to another block? That sounds difficult in many cases and highly dependent on the data. Are we simply talking about a new field array to specify block ghost level and pipeline keys to request them? What sources will support them? Should the requests be different than ghost cells for parallel distribution? |
(0037556) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-03-06 14:30 | Berk Geveci | New Issue | |
2008-03-06 14:42 | Berk Geveci | Target Version | => Multi-block support |
2008-03-06 14:50 | Berk Geveci | Status | backlog => tabled |
2008-03-06 14:50 | Berk Geveci | Assigned To | => Berk Geveci |
2008-04-24 13:44 | Berk Geveci | Category | 3.4 => 3.6 |
2009-02-17 13:40 | Ken Moreland | Note Added: 0015042 | |
2009-02-17 13:40 | Ken Moreland | Category | 3.6 => 3.8 |
2009-05-13 13:41 | Utkarsh Ayachit | Target Version | Multi-block support => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037556 | |
