| 0006675 | ParaView | (No Category) | public | 2008-03-28 14:28 | 2008-04-02 16:43 | ||||
| Reporter | Kevin H. Hobbs | ||||||||
| Assigned To | Berk Geveci | ||||||||
| Priority | normal | Severity | crash | Reproducibility | always | ||||
| Product Version | |||||||||
| Summary | 0006675: Crash ParaView3 Meta Image Save | ||||||||
| Description | ParaView3 crashes when I attempt to save an image in Meta Image (*.mhd) format. All I do is bring up the wavelet source and save the image in the Meta Image Format. ParaView exits and produces the following output: ERROR: In /home/kevin/kitware/ParaView3/Servers/Common/vtkProcessModule.cxx, line 1006 vtkProcessModule (0x80dbe0): Object type: vtkMetaImageWriter, could not find requested method: "SetFileType" or the method was called with incorrect arguments. while processing Message 0 = Invoke Argument 0 = id_value {359} Argument 1 = string_value {SetFileType} Argument 2 = int32_value {2} ERROR: In /home/kevin/kitware/ParaView3/Servers/Common/vtkProcessModule.cxx, line 1007 vtkProcessModule (0x80dbe0): Aborting execution for debugging purposes. Aborted | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0010969) Berk Geveci (administrator) 2008-03-28 18:43 |
revision 1.24 date: 2008-03-28 17:23:45 -0400; author: berk; state: Exp; lines: +9 -3; com mitid: e2oS7vM3xBIybWWs; BUG: MHD writer does not have a FileType property. Fixed XML. |
(0011046) Alan Scott (manager) 2008-04-02 16:43 |
Fixed. Tested local, since this reader does not work in parallel. |
| Notes |
| Issue History | |||
| 2008-03-28 14:28 | Kevin H. Hobbs | New Issue | |
| 2008-03-28 18:43 | Berk Geveci | Status | backlog => @80@ |
| 2008-03-28 18:43 | Berk Geveci | Resolution | open => fixed |
| 2008-03-28 18:43 | Berk Geveci | Assigned To | => Berk Geveci |
| 2008-03-28 18:43 | Berk Geveci | Note Added: 0010969 | |
| 2008-04-02 16:43 | Alan Scott | Status | @80@ => closed |
| 2008-04-02 16:43 | Alan Scott | Note Added: 0011046 | |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
