0006694 | ParaView | (No Category) | public | 2008-04-01 11:59 | 2008-04-07 19:24 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0006694: Change default color map | ||||||||
Description | Right now, the default color map is hard coded. There should be a way for the user to change the default color map. | ||||||||
(0011063) Utkarsh Ayachit (administrator) 2008-04-03 14:13 |
The color scale editor dialog has a "Make Default" button. When pressed the current color scale will become the default that will be used when a new lookup table is created. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMProxy.h,v <-- Servers/ServerManager/vtkSMProxy.h new revision: 1.84; previous revision: 1.83 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLookupTableManager.h,v <-- Qt/Core/pqLookupTableManager.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqColorScaleDialog.ui,v <-- Qt/Components/Resources/UI/pqColorScaleDialog.ui new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPQLookupTableManager.h,v <-- Qt/Components/pqPQLookupTableManager.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Components/pqPQLookupTableManager.cxx,v <-- Qt/Components/pqPQLookupTableManager.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.h,v <-- Qt/Components/pqColorScaleEditor.h new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.40; previous revision: 1.39 |
(0011141) Alan Scott (manager) 2008-04-07 19:24 |
Checked client/server |
2008-04-01 11:59 | Ken Moreland | New Issue | |
2008-04-02 18:08 | Utkarsh Ayachit | Status | backlog => tabled |
2008-04-02 18:08 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-04-03 14:13 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-03 14:13 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-03 14:13 | Utkarsh Ayachit | Note Added: 0011063 | |
2008-04-07 19:24 | Alan Scott | Status | @80@ => closed |
2008-04-07 19:24 | Alan Scott | Note Added: 0011141 | |
