| 0006698 | ParaView | (No Category) | public | 2008-04-01 15:27 | 2011-01-13 17:00 | ||||
| Reporter | Berk Geveci | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | unable to reproduce | ||||||
| Product Version | |||||||||
| Target Version | 3.6 | Fixed in Version | |||||||
| Summary | 0006698: Multi-block writer does not work in parallel | ||||||||
| Description | vtkXMLCompositeDataWriter does not work in parallel. Each processor writes its blocks using a serial writer. If multiple processors share the same block, they all write to the same file, causing corruption. Maybe we should use parallel writers? | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0011020) Berk Geveci (administrator) 2008-04-01 16:20 |
Instead of using parallel writer (which is difficult due to the possibility of null or empty nodes), we could have the composite reader/writer handle this case. Every piece would make sure to assign a different filename and when more than one node have a block for the same node, the file would like the following: <?xml version="1.0"?> <VTKFile type="vtkMultiBlockDataSet" version="1.0" byte_order="LittleEndian" compressor="vtkZLibDataCompressor"> <vtkMultiBlockDataSet> <DataSet index="0" file="mb/mb_0.vtp"/> <Block index="1"> <DataSet index="0" file="mb/mb_1_0.vtp"/> <DataSet index="0" file="mb/mb_1_1.vtp"/> <DataSet index="1" file="mb/mb_2.vtp"/> </Block> </vtkMultiBlockDataSet> </VTKFile> The reader would deal with appending datasets with the same index. Only datasets that can be appended would be supported (i.e. no structured datasets) |
(0013225) Utkarsh Ayachit (administrator) 2008-08-29 08:35 |
vtkXMLCompositeDataWriter now works in parallel. Each process now always writes out files with process number encoded into the filename thus assuring that they are unique. Then when writing out the meta-file the root process locates all leaf nodes that have non-null datasets on more than 1 process and inserts a multi-piece at that location. eg. writing out can.ex2 on 3 processes results in following XML <?xml version="1.0"?> <VTKFile type="vtkMultiBlockDataSet" version="1.0" byte_order="LittleEndian" compressor="vtkZLibDataCompressor"> <vtkMultiBlockDataSet> <Block index="0"> <Piece index="0"> <DataSet index="0" file="can/can_0_0.vtu"/> <DataSet index="1" file="can/can_1_0.vtu"/> <DataSet index="2" file="can/can_2_0.vtu"/> </Piece> <Piece index="1"> <DataSet index="0" file="can/can_0_1.vtu"/> <DataSet index="1" file="can/can_1_1.vtu"/> <DataSet index="2" file="can/can_2_1.vtu"/> </Piece> </Block> <Block index="1"/> <Block index="2"/> <Block index="3"/> <Block index="4"/> <Block index="5"/> <Block index="6"/> <Block index="7"/> </vtkMultiBlockDataSet> </VTKFile> /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.cxx,v <-- VTK/IO/vtkXMLCompositeDataWriter.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLCompositeDataWriter.h,v <-- VTK/IO/vtkXMLCompositeDataWriter.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPMultiBlockDataWriter.cxx,v <-- VTK/Parallel/vtkXMLPMultiBlockDataWriter.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkXMLPMultiBlockDataWriter.h,v <-- VTK/Parallel/vtkXMLPMultiBlockDataWriter.h new revision: 1.2; previous revision: 1.1 |
(0013365) Alan Scott (manager) 2008-09-08 17:08 |
Pushed back for feedback. I sent comments in a separate e-mail, along with an example bad dataset. |
(0015251) Utkarsh Ayachit (administrator) 2009-02-20 10:46 |
Alan, Can you retest this? I cannot reproduce the problem anymore. Thanks. |
(0015502) Alan Scott (manager) 2009-03-02 21:34 |
Tested client/ remote server. |
| Notes |
| Issue History | |||
| 2008-04-01 15:27 | Berk Geveci | New Issue | |
| 2008-04-01 16:20 | Berk Geveci | Note Added: 0011020 | |
| 2008-04-10 17:59 | Ken Moreland | Status | backlog => tabled |
| 2008-04-10 17:59 | Ken Moreland | Assigned To | => Berk Geveci |
| 2008-06-03 11:06 | Utkarsh Ayachit | Assigned To | Berk Geveci => Burlen |
| 2008-08-07 13:17 | Utkarsh Ayachit | Assigned To | Burlen => Berk Geveci |
| 2008-08-19 15:18 | Utkarsh Ayachit | Relationship added | related to 0006779 |
| 2008-08-27 15:37 | Berk Geveci | Assigned To | Berk Geveci => Utkarsh Ayachit |
| 2008-08-29 08:35 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-08-29 08:35 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-08-29 08:35 | Utkarsh Ayachit | Note Added: 0013225 | |
| 2008-09-08 17:08 | Alan Scott | Status | @80@ => @20@ |
| 2008-09-08 17:08 | Alan Scott | Resolution | fixed => reopened |
| 2008-09-08 17:08 | Alan Scott | Note Added: 0013365 | |
| 2009-02-17 14:09 | Ken Moreland | Category | 3.4 => 3.6 |
| 2009-02-20 10:46 | Utkarsh Ayachit | Note Added: 0015251 | |
| 2009-02-20 10:46 | Utkarsh Ayachit | Status | @20@ => @80@ |
| 2009-02-20 10:46 | Utkarsh Ayachit | Resolution | reopened => unable to reproduce |
| 2009-03-02 21:34 | Alan Scott | Note Added: 0015502 | |
| 2009-03-02 21:34 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:46 | Utkarsh Ayachit | Target Version | Multi-block support => 3.6 |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
