0000067 | ParaView | (No Category) | public | 2003-07-08 16:47 | 2009-12-09 14:49 | ||||
Reporter | Berk Geveci | ||||||||
Priority | low | Severity | major | Reproducibility | always | ||||
Summary | 0000067: 64 bit server/32 bit client does not work | ||||||||
Description | Due to raw binary messaging between client and server, only 32 bit to 32 bit communication is supported. This should be fixed. | ||||||||
(0000934) Brad King (developer) 2004-04-21 18:37 |
Has anyone checked that this works with the new vtkClientServerStream-based implementation? |
(0001156) Brad King (developer) 2004-06-01 10:53 |
Almost everything seems to work as long as 64-bit IDs are on for both sides. The only known remaining problem is transfer of vtkLongArray data when sending data sets through the communicator. I'm reassigning this to Berk. |
2007-08-03 17:53 | Berk Geveci | Assigned To | David Cole => Berk Geveci |
2007-08-03 17:53 | Berk Geveci | Priority | high => low |
2007-08-03 17:53 | Berk Geveci | Status | backlog => closed |
2007-08-03 17:53 | Berk Geveci | Resolution | reopened => fixed |
2007-08-03 17:53 | Berk Geveci | Summary | Goodsite => 64 bit server/32 bit client does not work |
2007-08-03 17:53 | Berk Geveci | Note Deleted: 0008232 | |
2007-08-03 17:53 | Berk Geveci | Project | @4@ => @3@ |
2009-12-09 14:49 | Berk Geveci | Project | @3@ => ParaView |
