0006836 | ParaView | (No Category) | public | 2008-04-17 06:50 | 2016-08-12 09:57 | ||||
Reporter | Filip Sadlo | ||||||||
Assigned To | Robert Maynard | ||||||||
Priority | low | Severity | feature | Reproducibility | N/A | ||||
Summary | 0006836: Disabling widgets | ||||||||
Description | There seems to be no correct way to disable (gray out) widgets that are not considered in certain states of a module. I actually use the pqAutoGeneratedObjectPanel class and use findChild() for finding the corresponding QWidget by its name. Then I use setEnabled() for enabling/disabling. The problem is that the label of the widget should be disabled too. I construct the name of the label (from Qt/Components/pqNamedWidgets.cxx:createPanelLabel(): ParaView3.2: %s_label, ParaView3.3:_labelFor%s) und use that name for finding the QWidget of the label, certainly a hack. One solution could be to offer the programmer the possibility to retrieve the QWidget of the widget together with the QWidget of the label, e.g. by the name of the widget as defined in the XML file. | ||||||||
(0023439) Utkarsh Ayachit (administrator) 2010-11-19 13:32 |
We will simply connect the enabled/disabled signals from the widget to label. |
(0037567) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-04-17 06:50 | Filip Sadlo | New Issue | |
2008-04-17 09:43 | Ken Moreland | Category | 3.4 => 3.6 |
2009-02-17 15:49 | Ken Moreland | Category | 3.6 => Pending |
2009-02-20 10:52 | Ken Moreland | Category | Pending => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-19 13:32 | Utkarsh Ayachit | Note Added: 0023439 | |
2010-11-19 13:32 | Utkarsh Ayachit | Assigned To | => Robert Maynard |
2010-11-19 13:32 | Utkarsh Ayachit | Status | backlog => tabled |
2010-11-19 13:32 | Utkarsh Ayachit | Priority | normal => low |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037567 | |
