0007117 | ParaView | (No Category) | public | 2008-05-29 03:35 | 2010-12-01 21:37 | ||||
Reporter | Jean M. Favre | ||||||||
Target Version | 3.8 | Fixed in Version | 3.10 | ||||||
Summary | 0007117: reading Xdmf with stride different than 1 does not work in parallel | ||||||||
Description | When running a parallel server, bounds of a Xdmf rectilinear grid are not correct in the X, and Y direction. Grid resolution is correct (i.e the resolution is 1/N for stride=N), but physical extents are not. this is using the cvs version of May 29, 2008 Reading with strides, on a single node, works very well. | ||||||||
Attached Files | full_nodata.xmf [^] (42,420 bytes) 2008-05-29 03:35 | ||||||||
(0023445) Utkarsh Ayachit (administrator) 2010-11-19 13:51 |
This works with the new xdmf reader. |
(0023660) Alan Scott (manager) 2010-12-01 21:37 |
Trusting Utkarsh. I opened it up single and parallel, and both look the same (outline). I believe there is no data, thus it fails going to surface. If rendering surface crashes is a bug, please write that up as a new bug. |
2008-05-29 03:35 | Jean M. Favre | New Issue | |
2008-05-29 03:35 | Jean M. Favre | File Added: full_nodata.xmf | |
2008-06-03 11:44 | Utkarsh Ayachit | Category | 3.4 => 3.6 |
2009-02-17 16:31 | Ken Moreland | Category | 3.6 => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2010-11-19 13:51 | Utkarsh Ayachit | Note Added: 0023445 | |
2010-11-19 13:51 | Utkarsh Ayachit | Status | backlog => @80@ |
2010-11-19 13:51 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
2010-11-19 13:51 | Utkarsh Ayachit | Resolution | open => no change required |
2010-11-19 13:51 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2010-12-01 21:37 | Alan Scott | Note Added: 0023660 | |
2010-12-01 21:37 | Alan Scott | Status | @80@ => closed |
