0007206 | ParaView | (No Category) | public | 2008-06-19 04:15 | 2011-01-13 17:00 | ||||
Reporter | John Biddiscombe | ||||||||
Summary | 0007206: xml read/write broken | ||||||||
Description | Lots of changes to XML read/write were committed recently. When I do Source->New->Box/line/etc Save as pvd Load file I get segfault. This->CurrentOutputInformation is a null pointer and I had a look, but wasn't sure what to change. | ||||||||
(0012435) Utkarsh Ayachit (administrator) 2008-06-20 09:31 |
CopyOutputInformation is used by XMLCollection writers to copy the information from the readers output port to the information object passed. It does indeed expect to use the readers actual output port as the source for the information. This method never gets called during ProcessRequest of the reader so it doesn't make sense to use GetCurrentOutputInformation() anyways. ----------------------- commitid: KNFGfkAotbjFQG7t; ----------------------- /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLDataReader.cxx,v <-- VTK/IO/vtkXMLDataReader.cxx new revision: 1.38; previous revision: 1.37 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLPDataReader.cxx,v <-- VTK/IO/vtkXMLPDataReader.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLImageDataReader.cxx,v <-- VTK/IO/vtkXMLImageDataReader.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLPImageDataReader.cxx,v <-- VTK/IO/vtkXMLPImageDataReader.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLPStructuredDataReader.cxx,v <-- VTK/IO/vtkXMLPStructuredDataReader.cxx new revision: 1.26; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLPUnstructuredDataReader.cxx,v <-- VTK/IO/vtkXMLPUnstructuredDataReader.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLStructuredDataReader.cxx,v <-- VTK/IO/vtkXMLStructuredDataReader.cxx new revision: 1.28; previous revision: 1.27 |
(0012436) Utkarsh Ayachit (administrator) 2008-06-20 09:34 |
Oops...not fully fixed :). |
(0012437) Utkarsh Ayachit (administrator) 2008-06-20 09:40 |
Missed a few files. /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLUnstructuredDataReader.cxx,v <-- VTK/IO/vtkXMLUnstructuredDataReader.cxx new revision: 1.31; previous revision: 1.30 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLPUnstructuredDataReader.cxx,v <-- VTK/IO/vtkXMLPUnstructuredDataReader.cxx new revision: 1.22; previous revision: 1.21 |
(0012489) Alan Scott (manager) 2008-06-23 21:20 |
Tested client/server |
2008-06-19 04:15 | John Biddiscombe | New Issue | |
2008-06-20 09:30 | Utkarsh Ayachit | Status | backlog => tabled |
2008-06-20 09:30 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-06-20 09:31 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-06-20 09:31 | Utkarsh Ayachit | Resolution | open => fixed |
2008-06-20 09:31 | Utkarsh Ayachit | Note Added: 0012435 | |
2008-06-20 09:34 | Utkarsh Ayachit | Status | @80@ => @20@ |
2008-06-20 09:34 | Utkarsh Ayachit | Resolution | fixed => reopened |
2008-06-20 09:34 | Utkarsh Ayachit | Note Added: 0012436 | |
2008-06-20 09:35 | Utkarsh Ayachit | Status | @20@ => @30@ |
2008-06-20 09:40 | Utkarsh Ayachit | Status | @30@ => @80@ |
2008-06-20 09:40 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-06-20 09:40 | Utkarsh Ayachit | Note Added: 0012437 | |
2008-06-23 21:20 | Alan Scott | Status | @80@ => closed |
2008-06-23 21:20 | Alan Scott | Note Added: 0012489 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
