Attached Files | interval.pvsm [^] (130,409 bytes) 2008-06-25 05:24
BugFix-7238-Oct-9-2008.diff [^] (24,361 bytes) 2008-10-10 15:55 [Show Content] [Hide Content]diff --git a/Qt/Components/pqMultiView.cxx b/Qt/Components/pqMultiView.cxx
index 12b9cc2..9197561 100644
--- a/Qt/Components/pqMultiView.cxx
+++ b/Qt/Components/pqMultiView.cxx
@@ -495,6 +495,129 @@ QWidget* pqMultiView::widgetOfIndex(Index index)
+// This method computes values of ViewPosition and ViewSize for each
+// frame in the multiview. The values are computed so that gaps
+// created by splitter handles and view titlebars are eliminated.
+// This method calls the recursive method computeCompactSizesHelper.
+// ViewPosition is stored as a QPoint and ViewSize is stored as a QSize.
+void pqMultiView::computeCompactSizes(
+ QMap<pqMultiViewFrame*, QPair<QPoint,QSize> >& ViewInfo) const
+ // Call the recursive helper method
+ this->computeCompactSizesHelper(
+ ViewInfo,
+ qobject_cast<QSplitter*>(this->getMultiViewWidget()),
+ 0, 0, 0, 0);
+// A recursive method to compute ViewSize and ViewPosition for each frame
+// in the multiview. The multiview contains nested splitters which can
+// be thought of as a tree. The strategy is to keep track of splitter handle
+// locations while visiting each node in depth first order.
+// If there is a splitter handle on the right or bottom, then padding is added
+// to the right or bottom side. If there is a splitter handle on the left
+// or top, then padding is added on the left or top and ViewPosition is adjusted
+// the same number of pixels as the padding.
+void pqMultiView::computeCompactSizesHelper(
+ QMap<pqMultiViewFrame*, QPair<QPoint,QSize> >& ViewInfo,
+ QSplitter* splitter, int lflag, int rflag, int tflag, int bflag) const
+ if (!splitter) // Check for null just in case
+ return;
+ // Get info about this splitter
+ int numFrames = splitter->count();
+ int handlePadding = splitter->handleWidth()/2;
+ Qt::Orientation orientation = splitter->orientation();
+ // For each widget in the splitter
+ for (int i = 0; i < numFrames; ++i)
+ // This is the logic that tracks splitter handle
+ // locations. The flags rflag and bflag are
+ // incremented/decremented, while lflag and bflag
+ // are either 1 or 0.
+ if (i == 0)
+ if (orientation == Qt::Horizontal) rflag++;
+ if (orientation == Qt::Vertical) bflag++;
+ else if (i == 1)
+ if (orientation == Qt::Horizontal) lflag=1;
+ if (orientation == Qt::Vertical) tflag=1;
+ if (i == numFrames-1)
+ if (orientation == Qt::Horizontal) rflag--;
+ if (orientation == Qt::Vertical) bflag--;
+ // Get the child widget
+ QWidget * child = splitter->widget(i);
+ // The widget is either a splitter of a multi view frame
+ QSplitter * childSplitter = qobject_cast<QSplitter*>(child);
+ pqMultiViewFrame * childFrame = qobject_cast<pqMultiViewFrame*>(child);
+ if (childSplitter) // It's a splitter
+ // Recurse!
+ this->computeCompactSizesHelper(ViewInfo, childSplitter, lflag, rflag, tflag, bflag);
+ else if (childFrame) // It's a multi view frame
+ // Get size of frame
+ QSize size = childFrame->size();
+ // Get the position of the frame
+ QPoint position =
+ childFrame->mapTo(this->getMultiViewWidget(), QPoint(0,0));
+ // Expand size and adjust position as needed
+ if (rflag)
+ size.rwidth() += handlePadding;
+ if (bflag)
+ size.rheight() += handlePadding;
+ if (lflag)
+ position.rx() -= handlePadding;
+ if (tflag)
+ position.ry() -= handlePadding;
+ // Store the size and position in the map
+ ViewInfo[childFrame] = qMakePair(position, size);
+// Returns the top level splitter widget
+QWidget* pqMultiView::getMultiViewWidget() const
+ return this->SplitterFrame->layout()->itemAt(0)->widget();
Qt::Orientation pqMultiView::widgetOrientation(QWidget* _widget) const
QSplitter *splitter = qobject_cast<QSplitter *>(_widget->parentWidget());
diff --git a/Qt/Components/pqMultiView.h b/Qt/Components/pqMultiView.h
index 73ec68f..664cdb8 100644
--- a/Qt/Components/pqMultiView.h
+++ b/Qt/Components/pqMultiView.h
@@ -152,6 +152,11 @@ protected:
QFrame* MaximizeFrame;
pqMultiViewFrame* FillerFrame;
+ QWidget* getMultiViewWidget() const;
+ void computeCompactSizes(QMap<pqMultiViewFrame*, QPair<QPoint,QSize> >&) const;
+ void computeCompactSizesHelper(QMap<pqMultiViewFrame*, QPair<QPoint,QSize> >&,
+ QSplitter*, int, int, int, int) const;
private:
void saveSplitter(vtkPVXMLElement *element, QSplitter *splitter, int index);
void restoreSplitter(QWidget *widget, vtkPVXMLElement *element);
diff --git a/Qt/Components/pqViewManager.cxx b/Qt/Components/pqViewManager.cxx
index b59e679..30e55f0 100644
--- a/Qt/Components/pqViewManager.cxx
+++ b/Qt/Components/pqViewManager.cxx
@@ -1016,6 +1016,66 @@ void pqViewManager::updateViewPositions()
emit this->endNonUndoableChanges();
+ this->updateCompactViewPositions();
+// This method is called at the end of updateViewPositions().
+// This method tries to set the properties GUISizeCompact,
+// ViewPositionCompact, and ViewSizeCompact. For now, only the
+// vtkSMIceTMultiDisplayRenderViewProxy has these properties.
+void pqViewManager::updateCompactViewPositions()
+ QMap<pqMultiViewFrame*, QPair<QPoint, QSize> > ViewInfo;
+ this->computeCompactSizes(ViewInfo);
+ QSize totalGUISize = this->getMultiViewWidget()->size();
+ /// GUISize, ViewSize and ViewPosition properties are managed
+ /// by the GUI, the undo/redo stack should not worry about
+ /// the changes made to them.
+ emit this->beginNonUndoableChanges();
+ // Loop for each view
+ QList<pqMultiViewFrame*> frames = ViewInfo.keys();
+ foreach(pqMultiViewFrame* frame, frames)
+ pqView * view = this->getView(frame);
+ if (!view)
+ continue;
+ vtkSMIntVectorProperty* prop = 0;
+ // Set GUISize
+ prop = vtkSMIntVectorProperty::SafeDownCast(
+ view->getProxy()->GetProperty("GUISizeCompact"));
+ if(prop)
+ prop->SetElements2(totalGUISize.width(), totalGUISize.height());
+ // Set ViewPosition
+ view->getProxy()->GetProperty("ViewPositionCompact"));
+ if(prop)
+ QPoint pos = ViewInfo[frame].first;
+ prop->SetElements2(pos.x(), pos.y());
+ // Set ViewSize
+ view->getProxy()->GetProperty("ViewSizeCompact"));
+ if (prop)
+ QSize size = ViewInfo[frame].second;
+ prop->SetElements2(size.width(), size.height());
+ emit this->endNonUndoableChanges();
diff --git a/Qt/Components/pqViewManager.h b/Qt/Components/pqViewManager.h
index 1f6ebcf..2f6f72f 100644
--- a/Qt/Components/pqViewManager.h
+++ b/Qt/Components/pqViewManager.h
@@ -229,6 +229,11 @@ protected:
/// on all view modules.
void updateViewPositions();
+ /// Update the GUISize/WindowPosition properties
+ /// using compact values to produce gapless multi views
+ /// on the render server.
+ void updateCompactViewPositions();
/// Updates the context menu.
void updateConversionActions(pqMultiViewFrame* frame);
diff --git a/Servers/Filters/vtkPVDesktopDeliveryClient.cxx b/Servers/Filters/vtkPVDesktopDeliveryClient.cxx
index 8afa1b6..e4f662f 100644
--- a/Servers/Filters/vtkPVDesktopDeliveryClient.cxx
+++ b/Servers/Filters/vtkPVDesktopDeliveryClient.cxx
@@ -64,6 +64,10 @@ vtkPVDesktopDeliveryClient::vtkPVDesktopDeliveryClient()
this->RemoteImageProcessingTime = 0.0;
this->TransferTime = 0.0;
+ this->GUISizeCompact[0] = this->GUISizeCompact[1] = 0;
+ this->ViewSizeCompact[0] = this->ViewSizeCompact[1] = 0;
+ this->ViewPositionCompact[0] = this->ViewPositionCompact[1] = 0;
vtkCallbackCommand *cbc = vtkCallbackCommand::New();
cbc->SetClientData(this);
cbc->SetCallback(vtkPVDesktopDeliveryClientReceiveImageCallback);
@@ -155,6 +159,9 @@ void vtkPVDesktopDeliveryClient::ComputeVisiblePropBounds(vtkRenderer *ren,
void vtkPVDesktopDeliveryClient::CollectWindowInformation(vtkMultiProcessStream& stream)
+ this->CollectWindowInformation2(stream);
+ return;
this->Superclass::CollectWindowInformation(stream);
vtkPVDesktopDeliveryServer::WindowGeometry winGeoInfo;
if ((this->GUISize[0] == 0) || (this->GUISize[1] == 0))
@@ -180,6 +187,72 @@ void vtkPVDesktopDeliveryClient::CollectWindowInformation(vtkMultiProcessStream&
squirtOptions.Enabled = this->Squirt;
squirtOptions.CompressLevel = this->SquirtCompressionLevel;
squirtOptions.Save(stream);
+// This method replaces the original SendWindowInformation.
+// This method checks to see if GUISizeCompact has been set.
+// If it has been set, then this method sends GUISizeCompact,
+// ViewSizeCompact, and ViewPositionCompact to the server.
+// If GUISizeCompact has not been set, this method will act
+// exactly as the original did. (sends GUISize and WindowPosition)
+void vtkPVDesktopDeliveryClient::CollectWindowInformation2(vtkMultiProcessStream& stream)
+ this->Superclass::CollectWindowInformation(stream);
+ vtkPVDesktopDeliveryServer::WindowGeometry winGeoInfo;
+ // If GUISizeCompact has been set to a non-zero value
+ // then we are using multi display, so we'll use the
+ // compact values to eliminate gaps on the server tile display.
+ if (this->GUISizeCompact[0] != 0 && this->GUISizeCompact[1] != 0)
+ winGeoInfo.GUISize[0] = this->GUISizeCompact[0];
+ winGeoInfo.GUISize[1] = this->GUISizeCompact[1];
+ winGeoInfo.ViewSize[0] = this->ViewSizeCompact[0];
+ winGeoInfo.ViewSize[1] = this->ViewSizeCompact[1];
+ winGeoInfo.Position[0] = this->ViewPositionCompact[0];
+ winGeoInfo.Position[1] = this->ViewPositionCompact[1];
+ else // Use regular values
+ winGeoInfo.GUISize[0] = this->GUISize[0];
+ winGeoInfo.GUISize[1] = this->GUISize[1];
+ winGeoInfo.ViewSize[0] = this->RenderWindow->GetActualSize()[0];
+ winGeoInfo.ViewSize[1] = this->RenderWindow->GetActualSize()[0];
+ winGeoInfo.Position[0] = this->WindowPosition[0];
+ winGeoInfo.Position[1] = this->WindowPosition[1];
+ // Flip Y possition to lower left to make things easier for server.
+ winGeoInfo.GUISize[1] - winGeoInfo.Position[1] - winGeoInfo.ViewSize[1];
+ // I'm not sure if this block is ever triggered, but for now lets leave it.
+ if ((winGeoInfo.GUISize[0] == 0) || (winGeoInfo.GUISize[1] == 0))
+ winGeoInfo.GUISize[0] = winGeoInfo.ViewSize[0];
+ winGeoInfo.GUISize[1] = winGeoInfo.ViewSize[1];
+ //printf("-----SendingWindowInformation-----\n");
+ //printf(" GuiSize: %d %d\n", winGeoInfo.GUISize[0], winGeoInfo.GUISize[1]);
+ //printf(" ViewPos: %d %d\n", winGeoInfo.Position[0], winGeoInfo.Position[1]);
+ //printf(" ViewSize: %d %d\n", winGeoInfo.ViewSize[0], winGeoInfo.ViewSize[1]);
+ winGeoInfo.Id = this->Id;
+ winGeoInfo.AnnotationLayer = this->AnnotationLayer;
+ winGeoInfo.Save(stream);
+ vtkPVDesktopDeliveryServer::SquirtOptions squirtOptions;
+ squirtOptions.Enabled = this->Squirt;
+ squirtOptions.CompressLevel = this->SquirtCompressionLevel;
+ squirtOptions.Save(stream);
diff --git a/Servers/Filters/vtkPVDesktopDeliveryClient.h b/Servers/Filters/vtkPVDesktopDeliveryClient.h
index 9ab89e6..b0a8564 100644
--- a/Servers/Filters/vtkPVDesktopDeliveryClient.h
+++ b/Servers/Filters/vtkPVDesktopDeliveryClient.h
@@ -153,6 +153,13 @@ public:
vtkGetVector2Macro(GUISize, int);
vtkSetVector2Macro(GUISize, int);
+ vtkGetVector2Macro(GUISizeCompact, int);
+ vtkSetVector2Macro(GUISizeCompact, int);
+ vtkGetVector2Macro(ViewSizeCompact, int);
+ vtkSetVector2Macro(ViewSizeCompact, int);
+ vtkGetVector2Macro(ViewPositionCompact, int);
+ vtkSetVector2Macro(ViewPositionCompact, int);
virtual void SetImageReductionFactorForUpdateRate(double desiredUpdateRate);
float GetZBufferValue(int x, int y);
@@ -175,6 +182,7 @@ protected:
double TransferTime;
virtual void CollectWindowInformation(vtkMultiProcessStream& stream);
+ virtual void CollectWindowInformation2(vtkMultiProcessStream& stream);
virtual void CollectRendererInformation(vtkRenderer *, vtkMultiProcessStream&);
// Squirt options (probably to be replaced later).
@@ -192,6 +200,10 @@ protected:
int WindowPosition[2];
int GUISize[2];
+ int GUISizeCompact[2];
+ int ViewSizeCompact[2];
+ int ViewPositionCompact[2];
int ReceivedImageFromServer;
vtkCommand *ReceiveImageCallback;
diff --git a/Servers/Filters/vtkPVDesktopDeliveryServer.cxx b/Servers/Filters/vtkPVDesktopDeliveryServer.cxx
index f23ecd4..a08950b 100644
--- a/Servers/Filters/vtkPVDesktopDeliveryServer.cxx
+++ b/Servers/Filters/vtkPVDesktopDeliveryServer.cxx
@@ -310,6 +310,8 @@ void vtkPVDesktopDeliveryServer::UseRendererSet(int id)
bool vtkPVDesktopDeliveryServer::ProcessWindowInformation(
+ return this->ProcessWindowInformation2(stream);
if (!this->Superclass::ProcessWindowInformation(stream))
return false;
@@ -351,6 +353,74 @@ bool vtkPVDesktopDeliveryServer::ProcessWindowInformation(
this->Squirt = squirtOptions.Enabled;
this->SquirtCompressionLevel = squirtOptions.CompressLevel;
return true;
+// This method replaces the original ProcessWindowInformation(vtkMultiProcessStream&).
+// In the original, this->ClientWindowSize is set to this->FullImageSize,
+// where this->FullImageSize was equal to client_render_window->GetActualSize()
+// In this method, this->ClientWindowSize is set to winGeoInfo.ViewSize,
+// where winGeoInfo.ViewSize is sent by vtkPVDesktopDeliveryClient.
+// vtkPVDesktopDeliveryClient sets winGeoInfo.Viewsize to either
+// to client_render_window->GetActualSize(), or to the ivar
+// CompactViewSize if the ivar is available. The ivar is only
+// available when using tile display (icetmultidisplay)
+bool vtkPVDesktopDeliveryServer::ProcessWindowInformation2(
+ vtkMultiProcessStream& stream)
+ if (!this->Superclass::ProcessWindowInformation(stream))
+ return false;
+ if (!winGeoInfo.Restore(stream))
+ vtkErrorMacro("Failed to read WindowGeometry info.");
+ return false;
+ // Correct window size.
+ this->ClientWindowSize[0] = winGeoInfo.ViewSize[0];
+ this->ClientWindowSize[1] = winGeoInfo.ViewSize[1];
+ this->ClientRequestedImageSize[0] = this->ReducedImageSize[0];
+ this->ClientRequestedImageSize[1] = this->ReducedImageSize[1];
+ this->FullImageSize[0] = winGeoInfo.GUISize[0];
+ this->FullImageSize[1] = winGeoInfo.GUISize[1];
+ this->ReducedImageSize[0]
+ = (int)(this->FullImageSize[0]/this->ImageReductionFactor);
+ this->ReducedImageSize[1]
+ = (int)(this->FullImageSize[1]/this->ImageReductionFactor);
+ this->ClientWindowPosition[0] = winGeoInfo.Position[0];
+ this->ClientWindowPosition[1] = winGeoInfo.Position[1];
+ this->ClientGUISize[0] = winGeoInfo.GUISize[0];
+ this->ClientGUISize[1] = winGeoInfo.GUISize[1];
+ //printf("-----ReceiveWindowInformation-----\n");
+ //printf(" ViewSize: %d %d\n", this->ClientWindowSize[0], this->ClientWindowSize[1]);
+ //printf(" ViewPos: %d %d\n", this->ClientWindowPosition[0], this->ClientWindowPosition[1]);
+ //printf(" GuiSize: %d %d\n", this->ClientGUISize[0], this->ClientGUISize[1]);
+ this->AnnotationLayer = winGeoInfo.AnnotationLayer;
+ this->UseRendererSet(winGeoInfo.Id);
+ if (!squirtOptions.Restore(stream))
+ vtkErrorMacro("Failed to read SquirtOptions.");
+ return false;
+ this->Squirt = squirtOptions.Enabled;
+ this->SquirtCompressionLevel = squirtOptions.CompressLevel;
+ return true;
@@ -783,6 +853,7 @@ void vtkPVDesktopDeliveryServer::WindowGeometry::Save(vtkMultiProcessStream& str
stream << vtkPVDesktopDeliveryServer::WINDOW_GEOMETRY_TAG;
stream << this->Position[0] << this->Position[1]
<< this->GUISize[0] << this->GUISize[1]
+ << this->ViewSize[0] << this->ViewSize[1]
<< this->Id
<< this->AnnotationLayer;
@@ -798,6 +869,7 @@ bool vtkPVDesktopDeliveryServer::WindowGeometry::Restore(vtkMultiProcessStream&
stream >> this->Position[0] >> this->Position[1]
>> this->GUISize[0] >> this->GUISize[1]
+ >> this->ViewSize[0] >> this->ViewSize[1]
>> this->Id
return true;
diff --git a/Servers/Filters/vtkPVDesktopDeliveryServer.h b/Servers/Filters/vtkPVDesktopDeliveryServer.h
index ed209c2..57d5879 100644
--- a/Servers/Filters/vtkPVDesktopDeliveryServer.h
+++ b/Servers/Filters/vtkPVDesktopDeliveryServer.h
@@ -134,6 +134,7 @@ public:
struct WindowGeometry {
int Position[2];
int GUISize[2];
+ int ViewSize[2];
int Id;
int AnnotationLayer;
void Save(vtkMultiProcessStream& stream);
@@ -185,6 +186,7 @@ protected:
virtual void ReadReducedImage();
virtual bool ProcessWindowInformation(vtkMultiProcessStream&);
+ virtual bool ProcessWindowInformation2(vtkMultiProcessStream&);
virtual bool ProcessRendererInformation(vtkRenderer *, vtkMultiProcessStream&);
int Squirt;
diff --git a/Servers/ServerManager/Resources/rendering.xml b/Servers/ServerManager/Resources/rendering.xml
index 87f51e9..97e67ad 100644
--- a/Servers/ServerManager/Resources/rendering.xml
+++ b/Servers/ServerManager/Resources/rendering.xml
@@ -4415,6 +4415,46 @@
</Documentation>
</DoubleVectorProperty>
+ <IntVectorProperty
+ name="ViewPositionCompact"
+ command="SetViewPositionCompact"
+ number_of_elements="2"
+ default_values="0 0"
+ update_self="1"
+ immediate_update="1">
+ <IntRangeDomain name="range" min="0 0" />
+ <Documentation>
+ Position of the view. This is useful in multiview configurations.
+ </Documentation>
+ </IntVectorProperty>
+ name="GUISizeCompact"
+ command="SetGUISizeCompact"
+ update_self="1"
+ <Documentation>
+ Total GUI size when using mutliple views. This includes the sizes of
+ all view modules.
+ </Documentation>
+ name="ViewSizeCompact"
+ command="SetViewSizeCompact"
+ update_self="1"
+ <Documentation>
+ The ViewSize to use for gapless multi display on the server.
+ </Documentation>
<!-- End of IceTMultiDisplayRenderView -->
</IceTMultiDisplayRenderViewProxy>
diff --git a/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx b/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx
index e16a031..e138f93 100644
--- a/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx
+++ b/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.cxx
@@ -39,6 +39,10 @@ vtkSMIceTMultiDisplayRenderViewProxy::vtkSMIceTMultiDisplayRenderViewProxy()
this->LastClientCollectionDecision = false;
this->Information->Set(CLIENT_RENDER(), 1);
this->Information->Set(CLIENT_COLLECT(), 0);
@@ -178,6 +182,43 @@ NewStrategyInternal(int dataType)
+void vtkSMIceTMultiDisplayRenderViewProxy::SetGUISizeCompact(int x, int y)
+ vtkProcessModule* pm = vtkProcessModule::GetProcessModule();
+ vtkClientServerStream stream;
+ stream << vtkClientServerStream::Invoke
+ << this->RenderSyncManager->GetID()
+ << "SetGUISizeCompact" << x << y
+ << vtkClientServerStream::End;
+ pm->SendStream(this->ConnectionID, vtkProcessModule::CLIENT, stream);
+void vtkSMIceTMultiDisplayRenderViewProxy::SetViewPositionCompact(int x, int y)
+ << "SetViewPositionCompact" << x << y
+void vtkSMIceTMultiDisplayRenderViewProxy::SetViewSizeCompact(int x, int y)
+ << "SetViewSizeCompact" << x << y
void vtkSMIceTMultiDisplayRenderViewProxy::SetGUISize(int x, int y)
@@ -219,3 +260,4 @@ void vtkSMIceTMultiDisplayRenderViewProxy::PrintSelf(ostream& os, vtkIndent inde
os << indent << "TileDisplayCompositeThreshold: "
<< this->TileDisplayCompositeThreshold << endl;
diff --git a/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h b/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h
index 830b009..5d66ca4 100644
--- a/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h
+++ b/Servers/ServerManager/vtkSMIceTMultiDisplayRenderViewProxy.h
@@ -68,6 +68,21 @@ public:
// Overridden to pass the ViewPosition to the RenderSyncManager.
virtual void SetViewPosition(int x, int y);
+ // Description:
+ virtual void SetGUISizeCompact(int x, int y);
+ // Description:
+ virtual void SetViewPositionCompact(int x, int y);
+ // Description:
+ virtual void SetViewSizeCompact(int x, int y);
//BTX
protected:
vtkSMIceTMultiDisplayRenderViewProxy();
@@ -115,6 +130,11 @@ protected:
double TileDisplayCompositeThreshold;
bool LastClientCollectionDecision;
private:
vtkSMIceTMultiDisplayRenderViewProxy(const vtkSMIceTMultiDisplayRenderViewProxy&); // Not implemented.
void operator=(const vtkSMIceTMultiDisplayRenderViewProxy&); // Not implemented.
