0007274 | ParaView | Bug | public | 2008-07-02 16:04 | 2016-08-12 09:57 | ||||
Reporter | Kent Eschenberg | ||||||||
Summary | 0007274: Structured data blanking ignored vtkDataSetSurfaceFilter | ||||||||
Description | It draws the blanked areas. | ||||||||
Additional Information | Blanking is performed for unstructured grids, and no other dataset type has blanking. I've added a method for this case that efficiently handles node and/or cell blanking. However, it ignores node and cell IDs; the request to keep the original cell ids; the request to generate triangle strips, and the update extent. Maybe later. | ||||||||
Attached Files | vtkDataSetSurfaceFilter.cxx [^] (66,070 bytes) 2008-07-02 16:04 vtkDataSetSurfaceFilter.h [^] (5,941 bytes) 2008-07-02 16:05 | ||||||||
(0037581) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-07-02 16:04 | Kent Eschenberg | New Issue | |
2008-07-02 16:04 | Kent Eschenberg | File Added: vtkDataSetSurfaceFilter.cxx | |
2008-07-02 16:05 | Kent Eschenberg | File Added: vtkDataSetSurfaceFilter.h | |
2010-11-05 13:43 | Utkarsh Ayachit | Category | => Bug |
2010-11-05 13:43 | Utkarsh Ayachit | Target Version | => 4.0 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037581 | |
2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
