0007275 | ParaView | (No Category) | public | 2008-07-02 19:26 | 2016-08-24 08:25 | ||||
Reporter | Philippe Pebay | ||||||||
Summary | 0007275: Cannot select output port #1 of a filter as the input of another filter | ||||||||
Description | Some filters (for instance vtk*Statistics used in OverView) sometimes require to two input ports. When adding such a filter to the pipeline, the first input port (#0) is selected by default to be the output port #0 of the previous filter. This is fine. However, when one also needs the set up the input port #1 with the "Choose Input..." option found by right-clicking on the filter in the pipeline browser, attempting to select output port #1 of the previous filter as the input port #1 of the current filter fails. More precisely, the input chooser lets the user make that selection, however after pressing "Ok", the input port #1 is reset to the output port #0 of the previous filter, effectively preventing the filter from being used. | ||||||||
Additional Information | It is easy to reproduce this bug with, for instance, the ContingencyStatistics filter in OverView: run a first such filter in "Learn" mode, then creat a second one, and try to connect the input/output ports #1 to each other. This should fail. | ||||||||
(0012604) Utkarsh Ayachit (administrator) 2008-07-03 09:01 |
vtkSMInputProperty::SetProxies() was incorrectly updating the internal port numbers vector. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMInputProperty.cxx,v <-- Servers/ServerManager/vtkSMInputProperty.cxx new revision: 1.23; previous revision: 1.22 |
(0012641) Alan Scott (manager) 2008-07-07 19:02 |
Not tested. |
(0012645) Philippe Pebay (reporter) 2008-07-07 19:10 |
Tested and works fine. |
(0012646) Alan Scott (manager) 2008-07-07 19:12 |
Thanks. Closed. |
2008-07-02 19:26 | Philippe Pebay | New Issue | |
2008-07-02 19:26 | Philippe Pebay | Status | backlog => tabled |
2008-07-02 19:26 | Philippe Pebay | Assigned To | => Utkarsh Ayachit |
2008-07-03 09:01 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-07-03 09:01 | Utkarsh Ayachit | Resolution | open => fixed |
2008-07-03 09:01 | Utkarsh Ayachit | Note Added: 0012604 | |
2008-07-07 19:02 | Alan Scott | Status | @80@ => closed |
2008-07-07 19:02 | Alan Scott | Note Added: 0012641 | |
2008-07-07 19:10 | Philippe Pebay | Status | closed => @80@ |
2008-07-07 19:10 | Philippe Pebay | Note Added: 0012645 | |
2008-07-07 19:12 | Alan Scott | Status | @80@ => closed |
2008-07-07 19:12 | Alan Scott | Note Added: 0012646 | |
2016-08-24 08:25 | Kitware Robot | View Status | private => public |
