0007352 | ParaView | (No Category) | public | 2008-07-17 11:30 | 2009-05-13 13:47 | ||||
Reporter | Burlen | ||||||||
Assigned To | Zhanping Liu | ||||||||
Summary | 0007352: export csv doesn't handle char data arrays | ||||||||
Description | vtkDataArrays of type char that are written to a csv file should be written as integer data, otherwise it is not readable by spread sheet/text editor. If these arrays are written directly as char's they are likely to contain control characters that are not viewable. | ||||||||
Attached Files | Bug.csv [^] (11,703 bytes) 2008-11-18 11:54 Fix.csv [^] (14,495 bytes) 2008-11-18 11:54 Patch.txt [^] (941 bytes) 2008-11-18 11:54 [Show Content] | ||||||||
(0014135) Zhanping Liu (developer) 2008-11-18 11:53 |
BUG: 0007352 has been fixed. The problem, i.e., the occurrence of weird characters (resulting from char / signed char / unsigned char variables) in an output CSV file, was caused by vtkCSVExporter::WriteData(...). For these three types (of vtkVariant), the output CSV file contains characters (see the attached file 'Bug.csv') that cannot be properly shown in a text viewer. Please see the attached patch file 'Patch.txt' for the fix to the bug and a properly generated CSV file 'Fix.CSV'. Thanks go to Burlen for the great help with bug re-production. new revision: 1.2; previous revision: 1.1. |
(0014420) Alan Scott (manager) 2008-12-22 20:40 |
Tested local client. I believe that there are other issues with writing csv files, but I will write up another bug. Thus, I am going off of the attached files. |
2008-07-17 11:30 | Burlen | New Issue | |
2008-11-14 15:40 | Utkarsh Ayachit | Status | backlog => tabled |
2008-11-14 15:40 | Utkarsh Ayachit | Assigned To | => Zhanping Liu |
2008-11-18 11:53 | Zhanping Liu | Note Added: 0014135 | |
2008-11-18 11:54 | Zhanping Liu | File Added: Bug.csv | |
2008-11-18 11:54 | Zhanping Liu | File Added: Fix.csv | |
2008-11-18 11:54 | Zhanping Liu | File Added: Patch.txt | |
2008-11-18 11:56 | Zhanping Liu | Status | tabled => @80@ |
2008-12-22 20:40 | Alan Scott | Note Added: 0014420 | |
2008-12-22 20:40 | Alan Scott | Status | @80@ => closed |
2008-12-22 20:40 | Alan Scott | Resolution | open => fixed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
