0007428 | ParaView | (No Category) | public | 2008-07-30 11:06 | 2016-08-12 09:57 | ||||
Priority | normal | Severity | feature | Reproducibility | have not tried | ||||
Summary | 0007428: Single block image volume rendering | ||||||||
Description | If you have a multiblock data set with a single unstructured grid, you can volume rendered it as if you just had an unstructured grid. You cannot do the same thing with image data. If you have a multiblock data set with a single 3D image data, you cannot volume render it. You should be able to. Please add this feature. | ||||||||
(0012880) Ken Moreland (manager) 2008-07-30 11:07 |
This will probably be released in a 3.4 patch. |
(0015254) Ken Moreland (manager) 2009-02-20 11:23 |
This may be harder to implement then it sounds. There will probably be extent issues. |
(0037585) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-07-30 11:06 | Ken Moreland | New Issue | |
2008-07-30 11:07 | Ken Moreland | Note Added: 0012880 | |
2008-08-26 13:47 | Utkarsh Ayachit | Status | backlog => tabled |
2008-08-26 13:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-18 09:05 | Utkarsh Ayachit | Category | 3.4 => Pending |
2009-02-20 11:23 | Ken Moreland | Note Added: 0015254 | |
2009-02-20 11:23 | Ken Moreland | Category | Pending => 3.8 |
2009-05-13 13:40 | Utkarsh Ayachit | Target Version | => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037585 | |
