0007495 | ParaView | (No Category) | public | 2008-08-15 19:26 | 2009-02-18 15:12 | ||||
Reporter | Daniel Goldstein | ||||||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0007495: Coloring with glyph filter | ||||||||
Description | PV version 3.3.1 (development) with the glyph filer, when glyph type: Line is chosen the coloring scheme reverts to coloring along the long (blue at root, red at head with std color map) at every redraw. Set glyph to be colored by something (say w). either start an animation or change anything in the pipeline to cause a redraw and color mode goes back to coloring along the line. Thanks! Keep up the great work. Dan | ||||||||
(0015129) Utkarsh Ayachit (administrator) 2009-02-18 08:54 |
Unable to reproduce. Seems to work fine for me. |
(0015163) Alan Scott (manager) 2009-02-18 15:12 |
Tested client/ remote server. If this bug still exists, please add better directions - for instance, what file are you opening, how do you set up the glyph filter, etc. Please try to replicate using one of the Paraview data files. |
2008-08-15 19:26 | Daniel Goldstein | New Issue | |
2009-02-18 08:54 | Utkarsh Ayachit | Note Added: 0015129 | |
2009-02-18 08:54 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-02-18 08:54 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-02-18 08:54 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-18 15:12 | Alan Scott | Note Added: 0015163 | |
2009-02-18 15:12 | Alan Scott | Status | @80@ => closed |
