0007516 | ParaView | (No Category) | public | 2008-08-20 14:48 | 2008-09-08 17:48 | ||||
Reporter | Daniel Goldstein | ||||||||
Priority | normal | Severity | text | Reproducibility | always | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0007516: Text Source looses font size when reading in saved state file. | ||||||||
Description | In PV 3.3.1 Dev and 3.2.1 when a PV session is saved that includes a text source the text is stuck in the smallest size when the session is reloaded. Make a PV session with a text source. Save it to a state file. Exit PV. Restart PV and load the saved session. The text from the text source is tiny. The strange thing is it won't even let me resize the text from the Object Insoector/Display panel. It is like it is locked as tiny. I am on a mac powerbook, macosx 10.5.1 This also happened on my winxp machine. Let me know if you cannot reproduce this. Thanks! Dan | ||||||||
Attached Files | BUG.7516.pvsm [^] (28,718 bytes) 2008-09-08 09:36 | ||||||||
(0013344) Utkarsh Ayachit (administrator) 2008-09-08 09:38 |
Works for me. Try loading the attached state. The text source shows up with font size "45" which is exactly what I saved the state as. Also I can change the font size without any issues. (tried with CVS head as of Sep 8, 08). Can you upload state file which illustrates the problem, if the problem still exists please? |
(0013369) Alan Scott (manager) 2008-09-08 17:48 |
Works for me as well. Tested client/server - XP client, Linux cluster server. Tested font size, font, opacity and color. |
2008-08-20 14:48 | Daniel Goldstein | New Issue | |
2008-09-08 09:36 | Utkarsh Ayachit | File Added: BUG.7516.pvsm | |
2008-09-08 09:38 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-09-08 09:38 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2008-09-08 09:38 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-09-08 09:38 | Utkarsh Ayachit | Note Added: 0013344 | |
2008-09-08 17:48 | Alan Scott | Status | @80@ => closed |
2008-09-08 17:48 | Alan Scott | Note Added: 0013369 | |
