0007549 | ParaView | Bug | public | 2008-08-26 10:43 | 2016-08-12 09:57 | ||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0007549: Camera issue when redoing 3D view creation | ||||||||
Description | The camera is not being properly set (or reset) when a 3D view is created with a redo action. To replicate, do the following: 1. Create any primitive object (e.g. Sources -> Cone) and Apply 2. Split the view either horizontally or vertically 3. With the new (blank) view selected, create another primitive object (e.g. Sources -> Cone) and Apply 4. Click the Undo button; the view goes blank as expected 5. Click the Redo button; the 3D view is recreated and the geometry put in it, but the camera is clearly not properly reset. The errant behavior is associated with creating the 3D View. You can get similar behavior by first deleting the one and only view, creating and applying a cone, then doing the undo/redo. | ||||||||
(0014085) Geoff Draper (reporter) 2008-11-10 16:02 |
Just wondering if there was any news on this issue. This bug is still reproducible as of 3 November 2008, when I did my most recent CVS checkout. Thanks! |
(0015291) Utkarsh Ayachit (administrator) 2009-02-23 10:56 |
This seems to have been fixed already. |
(0015359) Alan Scott (manager) 2009-02-24 20:47 |
It sure looked very, very wrong to me. From scratch, client/remote server. Numerous servers. XP client, trunk. As below, but I put a cone in the first window, a sphere in the second window. It is also replicable - I can go back and forward, and each forward is wrong - even though I then resize after each forward. |
(0015400) Alan Scott (manager) 2009-02-25 20:06 |
As stated above, this doesn't seem to be fixed to me... |
(0017400) Alan Scott (manager) 2009-09-11 19:28 |
I checked this against the trunk today, it is still bad. XP, local server. |
(0037588) Kitware Robot (administrator) 2016-08-12 09:57 |
2008-08-26 10:43 | Ken Moreland | New Issue | |
2008-11-10 16:02 | Geoff Draper | Note Added: 0014085 | |
2009-02-18 08:47 | Utkarsh Ayachit | Status | backlog => tabled |
2009-02-18 08:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-18 08:47 | Utkarsh Ayachit | Priority | normal => low |
2009-02-18 08:47 | Utkarsh Ayachit | Category | Development => 3.6 |
2009-02-23 10:56 | Utkarsh Ayachit | Note Added: 0015291 | |
2009-02-23 10:56 | Utkarsh Ayachit | Status | tabled => @80@ |
2009-02-23 10:56 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2009-02-24 20:47 | Alan Scott | Note Added: 0015359 | |
2009-02-24 20:47 | Alan Scott | Status | @80@ => @20@ |
2009-02-24 20:47 | Alan Scott | Resolution | unable to reproduce => reopened |
2009-02-24 20:55 | Alan Scott | Status | @20@ => tabled |
2009-02-24 20:55 | Alan Scott | Assigned To | Utkarsh Ayachit => Alan Scott |
2009-02-25 20:06 | Alan Scott | Note Added: 0015400 | |
2009-02-25 20:06 | Alan Scott | Assigned To | Alan Scott => Utkarsh Ayachit |
2009-02-25 20:06 | Alan Scott | Status | tabled => @20@ |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2009-08-25 12:10 | Ken Moreland | Category | => Bug |
2009-08-25 12:10 | Ken Moreland | Target Version | 3.6 => 3.6.2 |
2009-09-11 19:28 | Alan Scott | Note Added: 0017400 | |
2009-10-02 10:12 | Utkarsh Ayachit | Target Version | 3.6.2 => 3.8 |
2016-08-12 09:57 | Kitware Robot | Note Added: 0037588 | |
2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
