0007553 | ParaView | (No Category) | public | 2008-08-26 17:19 | 2009-05-13 13:47 | ||||
Summary | 0007553: Default glyph scaling crazy bad | ||||||||
Description | The default scaling used for glyphs is really, really bad. To replicate: 1. Create a sphere source. 2. Add a glyph filter with all the defaults. The resulting arrows will be scaled HUGE. | ||||||||
Relationships | ||||||
(0013486) Utkarsh Ayachit (administrator) 2008-09-17 09:43 |
BUG: Fixed BUG 0007690. The updating of the scale-factor was happenning before the property was pushed to the server mananger hence it was using obsolete values. Fixed by using Qt::QueuedConnection for the signal-slot connection. BUG: Fixed BUG 0007553. Needed to min-clamp the divisor for scaling to 1.0. /cvsroot/ParaView3/ParaView3/Qt/Components/pqGlyphPanel.cxx,v <-- Qt/Components/pqGlyphPanel.cxx new revision: 1.6; previous revision: 1.5 |
(0013605) Alan Scott (manager) 2008-09-26 20:07 |
Fantastic!!!! This fixes the problem with initial conditions for all vector lengths for glyphs, including with can! Great! Tested local client. |
2008-08-26 17:19 | Ken Moreland | New Issue | |
2008-09-16 16:38 | Utkarsh Ayachit | Status | backlog => tabled |
2008-09-16 16:38 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-09-16 22:04 | Ken Moreland | Relationship added | related to 0007690 |
2008-09-17 09:43 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-09-17 09:43 | Utkarsh Ayachit | Resolution | open => fixed |
2008-09-17 09:43 | Utkarsh Ayachit | Note Added: 0013486 | |
2008-09-26 20:07 | Alan Scott | Status | @80@ => closed |
2008-09-26 20:07 | Alan Scott | Note Added: 0013605 | |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
