0007607 | ParaView | (No Category) | public | 2008-09-04 15:12 | 2009-05-13 13:47 | ||||
Status | closed | Resolution | unable to reproduce | ||||||
Summary | 0007607: LOD Apply button, selections do not work | ||||||||
Description | I believe that the LOD selections Apply button does not work. This includes the LOD Resolution and Outline Threshold buttons. Run ParaView client/server (6 servers), open can.exo. Edit/ Options/ Render View/ General. Turn LOD Threshold on (select box), slide to 0.0 MBytes. Bug >> Slide the LOD Resolution slider back and forth, hitting Apply button. Nothing happens. Slide the LOD Resolution slider back and forth, hitting OK. It seems to work. Bug >> Slide the outline Threshold to 0 MCells, hit OK. Can still doesn't go to threshold representation. | ||||||||
(0013482) Utkarsh Ayachit (administrator) 2008-09-16 16:11 |
Bug 1>> Create a sphere with theta and phi resolution = 100. Change representation to wireframe. Now change the LOD resolution, hit apply and the interact. With CVS head, I see that the wireframe simplification changes with the LOD resolution as expected. Bug 2>> Outline Threhold is the only used when creating the representation (not when some data is already shown). So after chaning the threshold to 0, and existsing can.ex2 won't go to outline mode. However, if you load a new can.ex2 then it will show up as outline by default. The user can still change it to surface or whatever representation he chooses. |
(0013490) Alan Scott (manager) 2008-09-17 15:51 |
first bug appears to have been fixed. Second bug appears to be user error. Tested client/server. Closed. |
2008-09-04 15:12 | Alan Scott | New Issue | |
2008-09-16 16:11 | Utkarsh Ayachit | Status | backlog => @80@ |
2008-09-16 16:11 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
2008-09-16 16:11 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2008-09-16 16:11 | Utkarsh Ayachit | Note Added: 0013482 | |
2008-09-17 15:51 | Alan Scott | Status | @80@ => closed |
2008-09-17 15:51 | Alan Scott | Note Added: 0013490 | |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
