0007698 | ParaView | (No Category) | public | 2008-09-17 16:08 | 2009-05-13 13:47 | ||||
Priority | high | Severity | crash | Reproducibility | always | ||||
Summary | 0007698: Volume rendering crashes when blocks are selected | ||||||||
Description | ParaView crashes or hangs when we have blocks selected. * ParaView 3.5 trunk. client/server. * can.exo. All vars, apply. * Rotate the can so you can see it. * Select block - then select the can. * Change color by to PedigreeElementId. * Volume render. * It never comes back. :-( | ||||||||
(0013785) Utkarsh Ayachit (administrator) 2008-10-09 11:04 |
Is this problem reproducible when coloring with arrays other than pedigree-ids or global ids? |
(0013932) Alan Scott (manager) 2008-10-24 21:39 |
Yep, it is replicable. By the way, this seems to be the same as many of the other hangs I am seeing. XP client. 6 servers. Hard coding the useSsend switch in VTK/Parallel/vtkMPICommunicator.cxx. It always hangs in MPIMoveData (as reported at the bottom of the ParaView screen.) |
(0014125) Utkarsh Ayachit (administrator) 2008-11-17 09:49 |
There were several issues with updates when ordered compositing was used. Those have now been fixed. Consequently these hangs should be fixed as well. |
(0014170) Alan Scott (manager) 2008-11-24 21:48 |
This seems to have fixed this issue. Tested client/server. |
2008-09-17 16:08 | Alan Scott | New Issue | |
2008-10-06 15:48 | Alan Scott | Status | backlog => tabled |
2008-10-06 15:48 | Alan Scott | Assigned To | => Utkarsh Ayachit |
2008-10-09 11:04 | Utkarsh Ayachit | Note Added: 0013785 | |
2008-10-09 11:04 | Utkarsh Ayachit | Status | tabled => @20@ |
2008-10-24 21:39 | Alan Scott | Note Added: 0013932 | |
2008-10-24 21:39 | Alan Scott | Status | @20@ => @30@ |
2008-11-17 09:49 | Utkarsh Ayachit | Note Added: 0014125 | |
2008-11-17 09:49 | Utkarsh Ayachit | Status | @30@ => @80@ |
2008-11-17 09:49 | Utkarsh Ayachit | Resolution | open => fixed |
2008-11-24 21:48 | Alan Scott | Note Added: 0014170 | |
2008-11-24 21:48 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:47 | Utkarsh Ayachit | Target Version | => 3.6 |
