0007786 | ParaView | (No Category) | public | 2008-10-07 14:57 | 2011-01-13 17:00 | ||||
Summary | 0007786: Support vtkTable natively | ||||||||
Description | * Histogram and Probe produces vtkTables. ** For Histogram, the Table uses mid-points for bin-values. * vtkReductionFilter should use GatherV if possible for collecting data to the root node. * TableView (from Overview) remains in overview. ParaView hangs on to its spreadsheet view. The reason being that TableView has sorting etc which cannot be supported by spreadsheet view. * | ||||||||
Relationships | ||||||
(0014083) Utkarsh Ayachit (administrator) 2008-11-10 10:44 |
Adding support for vtkTables as first class data objects in Paraview. Fixes BUG 0007786. This covers a broad array of fixes/enhancments including: * Histrogram filter produces vtkTable. * Charts now use vtkTable (instead of vtkRectilinear grid). * Charts can plot any attribute data. * CSV Reader reads in vtkTable instead of vtkRectilinear. * Spreadsheet view cleanup -- the streaming logic is now more streamlined :). * Selection widget performance -- when a large number of cells/points were selected/unselected, the client would take a lot of time updating the selection inspector panel. This is now fixed. * Merging vtkTimeSeriesWriter into vtkParallelSerialWriter and fixing it to work with arbitrary data-objects rather than just vtkPolyData. /cvsroot/ParaView3/ParaView3/Qt/Components/CMakeLists.txt,v <-- Qt/Components/CMakeLists.txt new revision: 1.152; previous revision: 1.151 /cvsroot/ParaView3/ParaView3/Qt/Components/pqBarChartDisplayProxyEditor.cxx,v <-- Qt/Components/pqBarChartDisplayProxyEditor.cxx new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExtractDataSetsPanel.cxx,v <-- Qt/Components/pqExtractDataSetsPanel.cxx new revision: delete; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqExtractDataSetsPanel.h,v <-- Qt/Components/pqExtractDataSetsPanel.h new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqNamedWidgets.cxx,v <-- Qt/Components/pqNamedWidgets.cxx new revision: 1.51; previous revision: 1.50 /cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyInformationWidget.cxx,v <-- Qt/Components/pqProxyInformationWidget.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.cxx,v <-- Qt/Components/pqSelectionInspectorPanel.cxx new revision: 1.30; previous revision: 1.29 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSelectionInspectorPanel.h,v <-- Qt/Components/pqSelectionInspectorPanel.h new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx new revision: 1.10; previous revision: 1.9 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.h,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorSelectionTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorSelectionTreeWidget.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorSelectionTreeWidget.h,v <-- Qt/Components/pqSignalAdaptorSelectionTreeWidget.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorTreeWidget.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorTreeWidget.h,v <-- Qt/Components/pqSignalAdaptorTreeWidget.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSpreadSheetDisplayEditor.cxx,v <-- Qt/Components/pqSpreadSheetDisplayEditor.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSpreadSheetViewDecorator.cxx,v <-- Qt/Components/pqSpreadSheetViewDecorator.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/pqXYPlotDisplayProxyEditor.cxx,v <-- Qt/Components/pqXYPlotDisplayProxyEditor.cxx new revision: 1.27; previous revision: 1.26 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqBarChartDisplayEditor.ui,v <-- Qt/Components/Resources/UI/pqBarChartDisplayEditor.ui new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqExtractDataSetsPanel.ui,v <-- Qt/Components/Resources/UI/pqExtractDataSetsPanel.ui new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSpreadSheetDisplayEditor.ui,v <-- Qt/Components/Resources/UI/pqSpreadSheetDisplayEditor.ui new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqSpreadSheetViewDecorator.ui,v <-- Qt/Components/Resources/UI/pqSpreadSheetViewDecorator.ui new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/UI/pqXYPlotDisplayEditor.ui,v <-- Qt/Components/Resources/UI/pqXYPlotDisplayEditor.ui new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Core/pqBarChartRepresentation.cxx,v <-- Qt/Core/pqBarChartRepresentation.cxx new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Qt/Core/pqBarChartRepresentation.h,v <-- Qt/Core/pqBarChartRepresentation.h new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLineChartRepresentation.cxx,v <-- Qt/Core/pqLineChartRepresentation.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLineChartRepresentation.h,v <-- Qt/Core/pqLineChartRepresentation.h new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotView.cxx,v <-- Qt/Core/pqPlotView.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/Qt/Core/pqPlotViewHistogram.cxx,v <-- Qt/Core/pqPlotViewHistogram.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewModel.cxx,v <-- Qt/Core/pqSpreadSheetViewModel.cxx new revision: 1.26; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/Qt/Core/pqSpreadSheetViewSelectionModel.cxx,v <-- Qt/Core/pqSpreadSheetViewSelectionModel.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Qt/Core/pqVTKHistogramModel.cxx,v <-- Qt/Core/pqVTKHistogramModel.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Qt/Core/pqVTKHistogramModel.h,v <-- Qt/Core/pqVTKHistogramModel.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Widgets/CMakeLists.txt,v <-- Qt/Widgets/CMakeLists.txt new revision: 1.36; previous revision: 1.35 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidgetItem.cxx,v <-- Qt/Widgets/pqTreeWidgetItem.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqTreeWidgetItem.h,v <-- Qt/Widgets/pqTreeWidgetItem.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.cxx,v <-- Servers/Common/vtkPVDataInformation.cxx new revision: 1.59; previous revision: 1.58 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.h,v <-- Servers/Common/vtkPVDataInformation.h new revision: 1.29; previous revision: 1.28 /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.181; previous revision: 1.180 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAttributeDataReductionFilter.cxx,v <-- Servers/Filters/vtkAttributeDataReductionFilter.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAttributeDataReductionFilter.h,v <-- Servers/Filters/vtkAttributeDataReductionFilter.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAttributeDataToTableFilter.cxx,v <-- Servers/Filters/vtkAttributeDataToTableFilter.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkAttributeDataToTableFilter.h,v <-- Servers/Filters/vtkAttributeDataToTableFilter.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkBlockDeliveryPreprocessor.cxx,v <-- Servers/Filters/vtkBlockDeliveryPreprocessor.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkBlockDeliveryPreprocessor.h,v <-- Servers/Filters/vtkBlockDeliveryPreprocessor.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCSVReader.cxx,v <-- Servers/Filters/vtkCSVReader.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCSVReader.h,v <-- Servers/Filters/vtkCSVReader.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCSVWriter.cxx,v <-- Servers/Filters/vtkCSVWriter.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCSVWriter.h,v <-- Servers/Filters/vtkCSVWriter.h new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.cxx,v <-- Servers/Filters/vtkExtractHistogram.cxx new revision: 1.23; previous revision: 1.22 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkExtractHistogram.h,v <-- Servers/Filters/vtkExtractHistogram.h new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockFilter.cxx,v <-- Servers/Filters/vtkIndexBasedBlockFilter.cxx new revision: delete; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockFilter.h,v <-- Servers/Filters/vtkIndexBasedBlockFilter.h new revision: delete; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockSelectionFilter.cxx,v <-- Servers/Filters/vtkIndexBasedBlockSelectionFilter.cxx new revision: delete; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkIndexBasedBlockSelectionFilter.h,v <-- Servers/Filters/vtkIndexBasedBlockSelectionFilter.h new revision: delete; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPCSVWriter.cxx,v <-- Servers/Filters/vtkPCSVWriter.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPExtractHistogram.cxx,v <-- Servers/Filters/vtkPExtractHistogram.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVMergeTables.cxx,v <-- Servers/Filters/vtkPVMergeTables.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkPVMergeTables.h,v <-- Servers/Filters/vtkPVMergeTables.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkParallelSerialWriter.cxx,v <-- Servers/Filters/vtkParallelSerialWriter.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkParallelSerialWriter.h,v <-- Servers/Filters/vtkParallelSerialWriter.h new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkReductionFilter.cxx,v <-- Servers/Filters/vtkReductionFilter.cxx new revision: 1.19; previous revision: 1.18 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkReductionFilter.h,v <-- Servers/Filters/vtkReductionFilter.h new revision: 1.11; previous revision: 1.10 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkSelectionStreamer.cxx,v <-- Servers/Filters/vtkSelectionStreamer.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkSelectionStreamer.h,v <-- Servers/Filters/vtkSelectionStreamer.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTableStreamer.cxx,v <-- Servers/Filters/vtkTableStreamer.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTableStreamer.h,v <-- Servers/Filters/vtkTableStreamer.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeSeriesWriter.cxx,v <-- Servers/Filters/vtkTimeSeriesWriter.cxx new revision: delete; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkTimeSeriesWriter.h,v <-- Servers/Filters/vtkTimeSeriesWriter.h new revision: delete; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/Testing/Cxx/CMakeLists.txt,v <-- Servers/Filters/Testing/Cxx/CMakeLists.txt new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Servers/Filters/Testing/Cxx/TestExtractHistogram.cxx,v <-- Servers/Filters/Testing/Cxx/TestExtractHistogram.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/Filters/Testing/Cxx/TestTransferFunctionEditor.cxx,v <-- Servers/Filters/Testing/Cxx/TestTransferFunctionEditor.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/Filters/Testing/Cxx/TestTransferFunctionEditor2.cxx,v <-- Servers/Filters/Testing/Cxx/TestTransferFunctionEditor2.cxx new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/CMakeLists.txt,v <-- Servers/ServerManager/CMakeLists.txt new revision: 1.226; previous revision: 1.225 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMBlockDeliveryRepresentationProxy.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMCSVExporterProxy.cxx,v <-- Servers/ServerManager/vtkSMCSVExporterProxy.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMChartRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMChartRepresentationProxy.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMChartRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMChartRepresentationProxy.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientDeliveryRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMClientDeliveryRepresentationProxy.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMClientDeliveryRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMClientDeliveryRepresentationProxy.h new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMDataRepresentationProxy.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMEnumerationDomain.cxx,v <-- Servers/ServerManager/vtkSMEnumerationDomain.cxx new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMEnumerationDomain.h,v <-- Servers/ServerManager/vtkSMEnumerationDomain.h new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMFieldDataDomain.cxx,v <-- Servers/ServerManager/vtkSMFieldDataDomain.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMFieldDataDomain.h,v <-- Servers/ServerManager/vtkSMFieldDataDomain.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMIntVectorProperty.cxx,v <-- Servers/ServerManager/vtkSMIntVectorProperty.cxx |
(0014407) Utkarsh Ayachit (administrator) 2008-12-19 10:06 |
Adding new vtkTableToPolyData (Table To Points) to convert a vtkTable vertices in a vtkPolyData. /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkTableToPolyData.cxx,v <-- VTK/Graphics/vtkTableToPolyData.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkTableToPolyData.h,v <-- VTK/Graphics/vtkTableToPolyData.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Graphics/CMakeLists.txt,v <-- VTK/Graphics/CMakeLists.txt new revision: 1.198; previous revision: 1.197 /cvsroot/ParaView3/ParaView3/Qt/Components/Resources/XML/ParaViewFilters.xml,v <-- Qt/Components/Resources/XML/ParaViewFilters.xml new revision: 1.56; previous revision: 1.55 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.321; previous revision: 1.320 |
(0014409) Utkarsh Ayachit (administrator) 2008-12-19 11:11 |
Extract Arrays over time filters now produce vtkTable instead of vtkRectilinearGrid. /cvsroot/ParaView3/ParaView3/Qt/Core/pqDisplayPolicy.cxx,v <-- Qt/Core/pqDisplayPolicy.cxx new revision: 1.42; previous revision: 1.41 /cvsroot/ParaView3/ParaView3/Qt/Core/pqLineChartRepresentation.cxx,v <-- Qt/Core/pqLineChartRepresentation.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderViewBase.cxx,v <-- Qt/Core/pqRenderViewBase.cxx new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.322; previous revision: 1.321 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.cxx,v <-- VTK/Graphics/vtkExtractArraysOverTime.cxx new revision: 1.25; previous revision: 1.24 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.h,v <-- VTK/Graphics/vtkExtractArraysOverTime.h new revision: 1.12; previous revision: 1.11 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractTemporalFieldData.cxx,v <-- VTK/Graphics/vtkExtractTemporalFieldData.cxx new revision: 1.4; previous revision: 1.3 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractTemporalFieldData.h,v <-- VTK/Graphics/vtkExtractTemporalFieldData.h new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPExtractArraysOverTime.cxx,v <-- VTK/Parallel/vtkPExtractArraysOverTime.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/VTK/Parallel/vtkPExtractArraysOverTime.h,v <-- VTK/Parallel/vtkPExtractArraysOverTime.h new revision: 1.3; previous revision: 1.2 |
(0015052) Utkarsh Ayachit (administrator) 2009-02-17 14:13 |
The framework is in, and csv read-wrote/plot over time/histogram/spreadsheet support tables. |
(0015112) Alan Scott (manager) 2009-02-17 21:03 |
Wow, that's a lot of work for one feature/bug. |
2008-10-07 14:57 | Utkarsh Ayachit | New Issue | |
2008-11-10 10:44 | Utkarsh Ayachit | Note Added: 0014083 | |
2008-12-18 09:42 | Utkarsh Ayachit | Relationship added | related to 0007390 |
2008-12-19 10:06 | Utkarsh Ayachit | Note Added: 0014407 | |
2008-12-19 11:11 | Utkarsh Ayachit | Note Added: 0014409 | |
2009-02-17 14:13 | Utkarsh Ayachit | Note Added: 0015052 | |
2009-02-17 14:13 | Utkarsh Ayachit | Status | backlog => @80@ |
2009-02-17 14:13 | Utkarsh Ayachit | Resolution | open => fixed |
2009-02-17 14:13 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2009-02-17 21:03 | Alan Scott | Note Added: 0015112 | |
2009-02-17 21:03 | Alan Scott | Status | @80@ => closed |
2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
