0007787ParaView(No Category)public2008-10-07 15:032016-08-12 09:57
ReporterKen Moreland
Assigned ToBerk Geveci
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version
Summary0007787: Streamlines in x-z plane images wrong
DescriptionIf you run the streamlines filter on 2D image data defined in the x-z direction, then the streamlines come out wrong.
The attached state file demonstrates the problem. Note that running the streamlines directly on the image (left view) gives the wrong result whereas if you convert the data to unstructured grid and run streamlines on that (right view), you get the correct result.
TagsNo tags attached.
Project
Topic Name
Type
Attached Files? file icon XZGradientStreamlines.pvsm [^] (209,395 bytes) 2008-10-07 15:03
 Relationships
  Notes
(0037597)
Kitware Robot (administrator)
2016-08-12 09:57
Resolving issue as `moved`.
 Issue History
2008-10-07 15:03 Ken Moreland New Issue
2008-10-07 15:03 Ken Moreland File Added: XZGradientStreamlines.pvsm
2008-10-08 15:50 Berk Geveci Status backlog => tabled
2008-10-08 15:50 Berk Geveci Assigned To => Berk Geveci
2009-02-17 14:14 Utkarsh Ayachit Category 3.6 => 3.8
2009-05-13 13:41 Utkarsh Ayachit Target Version => 3.8
2016-08-12 09:57 Kitware Robot Note Added: 0037597
2016-08-12 09:57 Kitware Robot Status expired => closed
2016-08-12 09:57 Kitware Robot Resolution open => moved
